Previous in Forum: Pilots With Disabilities   Next in Forum: Equivalent Stress in Structure During Resonance?
Skyhook Equator. Orbiting Rotating Launcher Animator-Calculator
04/17/2026 3:11 PM
Skyhook Equator
Skyhook space megastructures for launching from equatorial skies to Earth orbits. Orbiting Rotating Launcher Animator-Calculator.
Skyhook (structure) – Wikipedia
I was inspired to author my “Skyhook Equator” animator-calculator webpage by NASA’s Artemis II mission around the moon – “for all humanity“.
Beta-testing began this week so bug reporting welcome - browser incompatibility issues, etc. Also if you want to challenge my physics - good luck with that too.
The web host only offers for free "http" not "https" so Chrome says "Not secure" but it's really not a problem since there is no confidential information asked for.
It's a computer script program so browser scripts must be allowed and enabled for the simulator and calculator to work. Pop-up blockers, ad-blockers, Noscript or anything at all which stops script programs working will stop it working. That's not a "bug" that needs reporting to me. It's really your choice to allow or disallow scripts as you please.
The attached screenshot shows what the webpage is supposed to look like, but you may have to zoom your browser out to see it like that. For best results view on a 3840 x 2160 monitor/TV. It's not designed to be viewed using a smartphone.
Suggestions for enhancements to the program are welcome.
Also if you want to discuss in this thread skyhooks or variations on the theme that would be appropriate in my opinion - including mentioning of alternative simulators, calculators for such things.
Demonstration video
Pathfinder Tags: bolo rotovator skyhook space-tether
Re: Skyhook Equator. Orbiting Rotating Launcher Animator-Calculator.
04/17/2026 5:44 PM
Intriguing. Entertaining!
iPhone16, and it seems to display for me just as your screenshot, the width displays more compact (less blue space).
The drop downs do not display for me; I didn’t alter my settings, so this was expected.
All in all, an engaging online calculator, even though not designed for mobile devices.
04/20/2026 6:37 AM
Thank you Doorman for your feedback.
That my Skyhook Equator program displays anything useful on a mobile device is more a testament to the device than to any intention or work on my part. I hadn't even looked at it on my own mobile until just now.
04/18/2026 11:21 PM
Your program looks awesome, though I'm not a rocket scientist so can't evaluate it the way you probably want. Are there plans to build a skyhook such as this? The cost would be extreme in my opinion. Also I think the tether would need to be stretchable so zylon might be too stiff. Nylon deteriorates when in the sun for a while. Being in upper atmosphere would add to that problem it seems, so the material used is a big problem to overcome.
04/20/2026 7:20 AM
"Your program looks awesome, though I'm not a rocket scientist so can't evaluate it the way you probably want."
Thanks StandardsGuy. Yes I would like rocket scientists to evaluate my calculator.
"Are there plans to build a skyhook such as this?"
Skyhook (structure) - Wikipedia
- has some information about proposals / plans. When searching the internet for other plans, best to pair the word "skyhook" with another like "space" or "orbit" to filter out other kinds of skyhooks.
The one other plan I would like to mention here and now is my Lunar Skyhook / Rotovator spreadsheet whose numbers suggest to me the possibility of building a combined lunar skyhook / space-station – a 250km – 300km long skyhook for landing and taking off from the moon also serving as a 1-G space-station.
"The cost would be extreme in my opinion."
Space megastructures - mega-costs.
"Also I think the tether would need to be stretchable so zylon might be too stiff."
Thank you for raising the important characteristic of stiffness.
The skyhook concept is also known as a "space-tether", but I suggest there are advantages of engineering a skyhook with greater lateral stiffness than the term "tether" implies.
In my opinion, a skyhook should be stiff enough laterally (stiff like a fencing sword rather than flexible like a whip) so that the rotation rate could be accelerated and braked by use of a counter-rotating flywheel.
The skyhook should be constructed in a "parking orbit" and able to be returned to that parking orbit at will for maintenance or to avoid collision with another critical low earth satellite, such as the International Space Station or the Hubble Space Telescope.
The skyhook would also have to absorb the shock of suddenly being loaded and unloaded by whatever it is that is being hooked or unhooked. Also the effective load would vary with each rotation - a maximum when hooking and a minimum at the hook's highest altitude, when gravitation partially opposes the centripetal acceleration.
"Nylon deteriorates when in the sun for a while. Being in upper atmosphere would add to that problem it seems, so the material used is a big problem to overcome."
There's very little in the way of atmosphere up there (most at the lowest, hooking altitude) but what there is, is fast-moving space debris and damaging radiation. So engineering a skyhook to last would be a difficult engineering problem.
10/09/2026 8:52 AM
Where i can find the link to this program?
10/09/2026 12:58 PM
The first line of the original post is an active link. I just tried it again, it is working for me.
If, for one reason or another, it doesn’t open for you, this one might work:
http://peterdow.scienceontheweb.net/skyhook/skyhookequator.htm
Doorman (2); Hameleon (1); Peter Dow (2); StandardsGuy (1)
