Previous in Forum: SupplierTR: Your Strategic Operational Partner   Next in Forum: How CMS Development Can Enhance Your Online Presence
15 comments
How to Convert OST to PST with MS Outlook?
04/21/2026 6:53 AM
Converting an OST (Offline Storage Table) file to a PST (Personal Storage Table) file in MS Outlook is a common task for users who need to move data from their local Outlook profiles or migrate from Exchange servers. Here's how you can do it manually:
Method 1: Export to PST via Outlook (Best for Regular Users)
  • Open Microsoft Outlook: Start Outlook with the profile linked to your OST file.
  • Ensure that Outlook is connected to the internet, particularly if you're using Exchange, so that all your data is synced.
  • Create a New PST File: Go to the File tab in Outlook.
  • Select Account Settings > Account Settings.
  • In the Account Settings window, click on the Data Files tab.
  • Click on Add to create a new PST file. Choose a location and name for this file.
  • Copy OST Data to PST: Go to the left panel of Outlook, and you'll see your OST data (e.g., Inbox, Sent Items, Calendar).
  • Right-click on the folder you want to convert (such as Inbox), and click Copy Folder.
  • Choose the newly created PST file as the destination and copy the data over.
  • Repeat for Other Folders: Repeat the same process for other folders like Sent Items, Calendar, Contacts, etc.
  • You can also manually drag and drop items (e.g., emails) from the OST folders to the PST folders.
  • Close Outlook: After the data has been copied, close Outlook. Your OST data should now be in the PST format and can be accessed anytime.
Method 2: Using the "Archive" Feature in Outlook
  • Open Microsoft Outlook: Open Outlook and ensure your OST file is connected.
  • Enable AutoArchive: Go to File > Options > Advanced.
  • Scroll down to AutoArchive Settings and make sure AutoArchive is enabled.
  • Manually Archive to PST: Click on the File tab again.
  • Select Tools and then Clean up old items or choose Archive.
  • Choose Archive this folder and all subfolders and select the folder(s) you want to archive (e.g., Inbox, Calendar).
  • Choose to archive items to a new PST file or an existing one.
  • Finish and Exit Outlook: After the archive process completes, the items will be stored in the PST file you created.
  • Close Outlook, and you’ll now have a PST file containing your data.
Alternative: Use a Reliable Third-Party Tool
If you have a large OST file or need a more efficient solution, third-party tools can help automate the process. Softaken OST to PST Converter is often recommended as a secure and reliable option. It can quickly convert OST files to PST, even if they are corrupted or inaccessible, without any data loss. Such tools also offer additional features, like batch conversion and compatibility with different versions of Outlook.
By using a third-party tool, you can save time and avoid potential risks of data corruption or errors during manual conversion. However, it's always important to choose a trustworthy and secure software solution for these tasks.
Quick Steps to Convert OST file to PST
  1. Download & Install OST Converter software from the official website.
  2. Launch the tool after installation.
  3. Add the OST file by clicking Add OST File and selecting your OST file.
  4. Choose the Output Location for the PST file.
  5. Click Convert to begin the conversion process.
Also posted in: also posted in Software & Programming
Re: How to Convert OST to PST with MS Outlook?
04/22/2026 3:47 AM
However, this manual method has limitations. It won’t work if the OST file is orphaned, corrupted, or disconnected from the Exchange server. In such cases, using a professional tool like FixVare OST to PST Converter is a better solution. This software allows you to convert OST files to PST without needing Outlook connectivity.
07/27/2026 5:28 AM
If you are facing any kinds of difficulty with converting OST file to PST format, then you can take help of Recoveryfix OST to PST Converter tool. It also convert OST data in PST, DBX, MBOX, MSG, EML, TXT, RTF, HTML, MHTML, PDF, DOC, and DOCX. This OST to PST Converter tool migrate data to another Outlook Profile.
Supported Versions:
  • MS Outlook - Office 365, 2021, 2019, 2016, 2013 (both 32 bit and 64 bit), 2010, 2007, 2003, 2002, 2000, 98, 97
  • Windows OS - Windows 365, 11, 10, 8.1, 8, 7, Vista, XP, 2000, 98, NT, 95 & Windows Server 2022, 2019 & older versions
04/23/2026 5:20 AM
There are various ways to convert OST to PST files. However, the professional tool can produce accurate outcomes after the OST to PST conversion. Therefore, all users should try the Shoviv OST to PST Converter tool, a third-party professional tool. It quickly converts multiple OST files to PST in a single go.
05/05/2026 2:46 AM
You can export your data using the Import/Export tool in Microsoft Outlook to convert OST to PST. Open Outlook and go to File > Open & Export > Import/Export > Export to a file > Outlook Data File (.pst). Choose the folders you want to convert and select a location to save it. This needs an active, linked OST file. For instance, the specific program like TrustVare OST to PST Converter is a specialized software.
05/07/2026 5:04 AM
Convert OST to PST without Outlook with Professional OST to PST Converter: https://apps.microsoft.com/detail/xpdf9sl8gl3x2f?hl=en-US&gl=US
05/13/2026 2:48 AM
If you are facing any kinds of difficulty with converting OST file, then you can take help of Recoveryfix OST to PST Converter tool to convert OST file to multiple file formats like PST, DBX, MBOX, MSG, EML, TXT, RTF, HTML, MHTML, PDF, DOC. It support all versions of MS Outlook - Office 365, 2021, 2019, 2016, 2013 (both 32 bit and 64 bit), 2010, 2007, 2003, 2002, 2000, 98, 97
05/16/2026 8:41 AM
As we know, there are various tools available on the internet to convert OST to PST files, but choosing a reliable and secure solution is very important. I would like to recommend the GoldyTools OST to PST Converter Tool, which is known for its accuracy and advanced conversion features.
The tool allows users to convert single as well as multiple OST files without any data loss. It supports exporting OST files into several formats, including PST, MSG, MBOX, HTML, PDF, EML, and EMLX. In addition, users can directly migrate OST mailbox data to platforms and email services such as Gmail, Yahoo Mail, Thunderbird, Office 365, and Yandex with ease.
Another major advantage of this tool is its ability to maintain folder hierarchy, email formatting, attachments, contacts, calendars, and other mailbox properties throughout the conversion process. It is also capable of recovering and converting corrupted or inaccessible OST files, making it a dependable solution for both personal and professional use.
05/18/2026 2:06 AM
If you are facing any kinds of difficulty with converting OST file to PST format, then I would like to suggest you to take the help of Recoveryfix OST to PST Converter tool. It convert OST data in PST, EML, TXT, RTF, DBX, MBOX, MSG, HTML, MHTML, PDF, DOC, and DOCX. The software supports all versions of MS Outlook like Office 365, 2021, 2019, 2016, 2013 (both 32 bit and 64 bit), 2010, 2007, 2003, 2002, 2000, 98, 97.
05/22/2026 4:00 AM
You can convert OST to PST in Microsoft Outlook using the Import/Export feature. Open Outlook, go to File > Open & Export > Import/Export, choose Export to a file, select Outlook Data File (.pst), and save the file.
This method works only if the OST file is accessible and connected to the original Outlook profile. If the OST is inaccessible, then you need a converting tool for it. Try out BLR OST to PST Converter for that.
06/19/2026 7:20 AM
Yes, you can easily migrate your OST file to PST using MS Outlook if the OST file is connected to an active Outlook profile.
Simple Steps to convert OST to PST with MS Outlook:
  1. Open MS Outlook.
  2. Click File.
  3. Select Open & Export.
  4. Click Import/Export.
  5. Choose Export to a file and click Next.
  6. Select Outlook Data File (.pst).
  7. Choose the mailbox you want to export.
  8. Enable Include subfolders if needed.
  9. Select a destination location.
  10. Click Finish to create the PST file.
However, this approach will not apply to orphaned, damaged, or inaccessible OST files. In this situation, you should use a dedicated tool like DataVare OST to PST Converter. I already used this solution a few months ago and my experience was very good with this tool, so that's why I'm suggesting you use this application. It is capable of converting OST file to PST with all emails, attachments, contacts, calendar, and folders intact without the need of an active Outlook session.
06/29/2026 8:41 AM
If your OST file is still connected to a working Outlook profile, you can convert it to PST using Outlook's built-in Export feature:
File → Open & Export → Import/Export → Export to a file → Outlook Data File (.pst), then choose the mailbox or folders you want to export.
However, this method only works if Outlook can access the OST file. If the OST is orphaned, corrupted, or the Exchange account is no longer available, you'll need a dedicated tool. The SysTools OST to PST Converter can convert inaccessible OST files to PST while preserving emails, contacts, calendars, attachments, and folder structure.
08/20/2026 7:44 AM
If Outlook is still connected to the original Exchange account, you may be able to export mailbox data to a PST using Outlook’s built-in export options. The problem comes when the OST file is orphaned, inaccessible, corrupted, or Outlook/Exchange is no longer available. In that situation, a dedicated converter is more practical.
WholeClear OST to PST Converter can scan an OST file independently and export emails, contacts, calendars, tasks, notes, attachments, and other mailbox items to PST. It also provides a preview, selective folder/item conversion, and maintains the original folder hierarchy. The tool can convert OST to PST without Outlook or Exchange Server, which is useful for disconnected OST files. I would test the free version first before processing the complete mailbox.
09/14/2026 6:23 AM
MailsDaddy OST to PST Converter is a reliable and user-friendly solution for converting OST files into PST format quickly and efficiently. It allows users to access and export important mailbox data, including emails, contacts, calendars, tasks, notes, and other items, while preserving the original folder structure and email properties. The software is designed to handle large and inaccessible OST files and offers a simple interface that makes the conversion process easy for both technical and non-technical users. Whether you need OST to PST conversion for Outlook migration, backup, recovery, or business requirements, MailsDaddy provides a convenient and secure way to manage your mailbox data with confidence.
10/01/2026 4:51 AM
The Outlook method is useful when the OST is still accessible through its associated Outlook profile. In that situation, you can use Outlook's Import/Export option to export mailbox folders to a PST file.
The situation is different when the OST has become orphaned, disconnected, or is no longer accessible through the original Outlook profile. Outlook may not be able to simply open that OST and export its contents.
For such cases, EdbMails OST to PST Converter can scan an accessible OST file, preview recoverable mailbox data, and export selected emails, attachments, contacts, calendars, and other mailbox items to PST. It can also work with offline, orphaned, disconnected, or damaged OST files; recovery results depend on the condition and readability of the source OST.
A sensible approach is to first use Outlook's native export option when the original profile is available. If that is not possible, evaluate an OST recovery/conversion tool and preview what can be recovered before purchasing.
10/31/2026 8:09 AM
When converting Microsoft Outlook .ost files into standard .pst format natively within Microsoft Outlook, you cannot simply open or import an orphaned OST file directly into another profile. Microsoft Outlook only allows OST data export if the OST file is actively connected and synchronized with its original Exchange, Office 365, or IMAP account.
Native Conversion via Microsoft Outlook
If your Outlook profile is active and connected to the account:
  1. Open Outlook and go to File > Open & Export > Import/Export.
  2. Select Export to a file and click Next.
  3. Choose Outlook Data File (.pst) and click Next.
  4. Select the specific folder or root directory to export, ensure Include subfolders is checked, and complete the export to your designated path.
Handling Orphaned or Inaccessible OST Files
If your Outlook profile is corrupt, deleted from the server, or the OST file is orphaned, Outlook’s native Import/Export feature will fail or disable access to the file due to MAPI SID account bindings.
BitRecover OST to PST Converter resolves orphaned and inaccessible OST file limitations by parsing the file structure directly offline without requiring an active Exchange server connection or an active Outlook profile. It maintains complete folder taxonomy, message headers, and embedded attachments during conversion.
Register to Reply 15 comments
allenrita (1); David_Garcia (1); jacksam (1); mackjohn (1); olivia2028 (1); philipspeter696 (1); rajatjaw (1); rowanfletcher (2); Ryan23 (1); shaunparker (1); sonu2shukla (2); valentina (1); willaksac (1)
