Previous in Forum: Calls   Next in Forum: How to Make a Link Linkable?
9 comments
Calculate BTU
04/23/2026 7:02 AM
In a two-pass tube and shell heat exchanger, there is incoming water at 160F degrees. It is heating 130F water at 400 Gpm to a temperature of 150F.
(The exiting water is further boosted outside of the exchanger, so it is irrelevant.)
So, how many BTU's/Hr are being saved by the exchanger.
Is it as simple to calculate as it seems?
Pathfinder Tags: calculate BTU
Re: Calculate BTU
04/23/2026 9:51 AM
Homework alert!
Are we to include the BTU required to heat the 160 water up again?
Aaaaand, the inevitable question… why not simply use that heat source to bring your process water up to 150F?
Re: Calculate BTU
04/23/2026 10:55 AM
This is waste heated water from dying and other processes used in the plant and would normally go to waste.
Re: Calculate BTU
04/23/2026 5:13 PM
BTU is the amount of energy to raise 1 lb of water 1 deg F
1 gal water is about 8 lb, 400 Gpm is about 3200 lb/min or about 192,000 lb/hour
192,000 lb/hr heated 20 deg F requires 3,840,000 BTU/hr
Good Answers: 25
Re: Calculate BTU
04/24/2026 12:30 PM
Good answer.
I used 8.3 lbs /gallon and came up with around 4 million BTU/hr
Troy
Good Answers: 137
Re: Calculate BTU
04/30/2026 11:59 AM
It's not hard to work out the heat flow, as #3 and #4, but that doesn't tell you anything about the flow rate on the hot side, or the heat exchange area needed (which are interrelated).
Re: Calculate BTU
05/25/2026 3:47 AM
I would suggest you approach the problem from the other side and calculate how much heat can be harvested from your 160F degrees flow. The flow rate on both sides, material and design of the heat exchanger will influence the rate of heat transfer and give you an idea of how much you will be cooling down one side and how much you will heat up the other side.
The simple calculations already given ignores the residence time inside the heat exchanger which is critical to the heat transfer. A lot more information is needed to know if heating up the water from 130F degrees to 15oF degrees is even feasible.
Good Answers: 137
Re: Calculate BTU
05/25/2026 5:17 AM
We already have the flow rate and temperature rise on the cold side, that gives the heat flow. The way I see it is the issue is finding the optimum design on the hot side, between large exchange area/low ΔT and small exchange area/high ΔT.
Re: Calculate BTU
09/10/2026 4:03 PM
Yes, it is. The activity needed is called an energy balance calculation, and well within the domain of the Process Engineer.
However, the temperatures of the streams are similar, so blending the two streams together into one is another possibility, which is also in the domain of the Process Engineer, and which might make the <...heat exchanger...> surplus to requirements.
Good Answers: 137
Re: Calculate BTU
09/11/2026 5:58 AM
It's the same activity whatever you call it. Best to approach 2-3 heat exchanger suppliers and ask them to quote their optimum design, and to state the hot side flow rate.
Register to Reply 9 comments
abotha (1); Codemaster (3); Doorman (1); HiTekRedNek (1); PWSlack (1); Rixter (1); Troy36 (1)
