Previous in Forum: Posting a Link   Next in Forum: Outlook PST Password Recovery Software for Instant Access
13 comments
What Is the Best Way to Convert EML to PST File?
05/06/2026 3:20 AM
If you are looking for the best way to convert EML to PST file, you can try a dedicated tool like MailsDaddy EML to PST Converter. The tool supports bulk conversion, keeps the original folder hierarchy, and preserves attachments as well as email formatting. Compatible with all versions of MS Outlook and Windows operating system. It smoothly works with all EML based email clients like Thunderbird, Outlook Express, Windows Live Mail, and others. Ideal choice for users who want a reliable and efficient conversion experience.
Re: What Is the Best Way to Convert EML to PST File?
05/07/2026 7:39 AM
To convert EML files into PST format, I think that using software that is specifically designed for email conversion is the simplest method. Handling it manually can be a time-consuming process, particularly when dealing with large files. Just lately, I utilized the WholeClear EML to PST Converter and I found that it performed without causing any issues. The converted PST file opened properly in Outlook, and the email content remains the same as the original files
Visit here: https://www.wholeclear.com/eml/pst/
05/07/2026 4:07 PM
These first two posts are informative and helpful.
But… please tell me, can anyone help me convert .pst to a .pdf when the parent file is a .dwg file imported to my computer with thumb drive?
All I get is gibberish… nonsense… buzzwords… usually reads like some spammer wrote it.
Please help. TIA!
05/08/2026 2:21 AM
If you want the best way to convert EML to PST file, then you landed in the right place. In this brief post, I’ll explain the most secure and reliable third-party tool named Shoviv EML to PST Converter tool. The tool is embedded with a strong algorithm and advanced features for the best results. Its step-by-step guide will provide you best results from the EML to PST conversion. Moreover, easily handles large-size EML files and converts them to Outlook PST in a single go. The tool allows users to convert EML files to different file formats like PST, and MSG.
05/15/2026 1:33 AM
With the help of Recoveryfix EML to PST Converter Tool to easily convert EML files to PST. The tool securely converts EML emails from multiple email clients into Outlook PST format while preserving folder hierarchy, attachments, metadata, and formatting. It supports bulk conversion, selective file export, and all Outlook versions.
05/15/2026 6:16 AM
One way is to directly import EML files into Outlook and save them as PST files. But this approach cannot be optimal when several emails are available. Some users want to have automatic tools to convert many files at once so they don't have to do it manually. I used Softaken EML to PST Converter when transferring my emails to Outlook to keep the formatting, files and organizational structure of my emails intact. It's easier when dealing with old email archives or bulk EML data
06/29/2026 8:39 AM
The best way to convert EML to PST is by using a dedicated EML to PST converter. Manual methods can be time-consuming and usually require Outlook.
A simple option is the SysTools EML to PST Converter. It lets you convert single or multiple EML files into a PST file while preserving emails, attachments, metadata, and folder hierarchy. It also supports bulk conversion, making it ideal for migrating emails from Windows Live Mail, Thunderbird, and other EML-based email clients to Outlook.
07/15/2026 3:55 AM
To accurately convert EML file to PST format, you can take help from CubexSoft EML to PST Converter. The software move batch EML files in Outlook PST format without any alteration in mail formatting. The tool provides variety of options to make sure 100% guaranteed outcomes. No technical skills is required to operate this tool. To check performance of the program, try demo edition of EML to Outlook Converter.
09/02/2026 1:02 AM
For a large number of EML files, I’d prefer using a dedicated EML to PST converter instead of importing each message manually into Outlook. The main things I would check are whether it supports batch conversion, preserves attachments and email formatting, and maintains the folder structure. I have used SysTools EML to PST Converter for this type of migration, and it was a straightforward option for converting multiple EML files into an Outlook-compatible PST. For only a few emails, though, a manual method may be sufficient.
08/01/2026 3:44 AM
I guess till now you might be trying to use Outlook to Convert your EML files to PST format - with a purpose of long term archiving - this can happen with older version of Outkook due to ASCII and Unicode related conflicts.
Another way to convert multiple unorganised eml file to Outlook Data File PST format is to a use a specialised software like BitRecover EML to PST Converter that can also help you separate PSTs, split PST by size, preservation of attachments, internet headers, read/unread status, metadata, and folder hierarchy
08/06/2026 2:18 AM
The easiest way is to use a dedicated EML to PST converter, especially if you want to transfer multiple EML files into Outlook without changing their original email details.
Follow these steps:
  1. Install and open an EML to PST conversion tool on your Windows system.
  2. Choose File Mode or Folder Mode to load the required EML files.
  3. Preview the imported emails to confirm you have selected the correct mailbox items.
  4. Select PST as the output format.
  5. Choose the destination folder where you want to save the PST file.
  6. Start the conversion and wait for it to complete.
  7. When done, open the created PST file in Microsoft Outlook.
If you have a large number of EML files or you want to avoid the limitations of manual methods, you can go for TrustVare EML to PST Converter. This offline utility provides batch conversion, lets you preview emails before export and preserves attachments and important email fields during migration. You can also try the demo edition first to see if it meets your conversion needs before upgrading.
09/14/2026 12:57 AM
This is well programmed that i have used to recover EML file into Outlook PST format. I have found this solution after read blogs.
09/28/2026 2:56 AM
If you have large number of EML files to convert, you can use a dedicated EML to PST Converter tool which is more convenient than doing manually through Outlook. Kernel EML to PST Converter is one option worth considering. You can easily convert your EML files to PST without your email content getting messed up. All your email content like attachments, metadata, formatting remains intact. Also, you can preview your EML files before converting in order to check whether the files converting are accurate or not.
10/26/2026 4:48 AM
The best way to convert EML to PST files depends on how many emails need to be transferred. If you have few EML files, then Outlook allows you the option to drag and drop emails in a mail folder, after which you can export this folder to a PST file, but this process becomes very time-consuming for handling hundreds or thousands of EML files. You can use a dedicated converter for EML to PST, which can be more reliable. The DataVare EML to PST Converter is the best tool for bulk conversion. This utility provides batch conversion of EML files generated by software like Thunderbird, Apple Mail, Windows Live Mail, and many others.
Register to Reply 13 comments
anthonytodd (1); Cameron (1); Doorman (1); harberjenny (1); jacksam (1); johndevis (1); Lakshita Nagpal (1); mackjohn (1); olivia2028 (1); rowanfletcher (1); Shivi (1); somit (1); sonu2shukla (1)
