Previous in Forum: Lubrication Fit for Electro-mechanical Parts   Next in Forum: Transformer RTD Temperature Settings
Knee Point Voltage from a Test Report
09/16/2026 11:23 AM
From this test report (CT), how to identify the saturation voltage (knee point) of the current transformer (CT).
for example on increasing voltage from 780V to 800V which is around increase in 2.5%, the current is increased to 100% (from 0.05A to 0.1A)
Am I reading it wrong?
Pathfinder Tags: ct Knee point
Re: Knee Point Voltage from a Test Report
09/17/2026 2:12 PM
The knee point in a current transformer (CT) is the specific voltage level on its excitation curve where the iron core begins to saturate, meaning a small 10% increase in secondary voltage requires a 50% increase in magnetizing current.
From the data, it appears that at 0.05A (and above) the core is already saturated.
An increase of 100% in current (0.05 -> 0.1 A) results in only a few percent in voltage.
09/18/2026 3:15 PM
Just a thought... these numbers appear to be made up --- is this a homework or test question?
09/19/2026 1:46 AM
This is from actual "test report" from the vendor; got it from the manufacturer after so many requests.
09/19/2026 8:13 PM
We have 5 data points from the data provided. The current I should increase 5 times the increase in voltage V.
I take the 5 data points provided, combine into 4 segments, calculate change in voltage and current, normalize to value of voltage and current, and then compare these normalized values.
Five samples
I = 0.050000 0.100000 0.200000 0.500000 1.000000 (Amps)
V = 780 800 820 840 860 (Volts)
Difference Four segments between 5 samples
dI = 0.050000 0.100000 0.300000 0.500000 (change in Amps)
dV = 20 20 20 20 (change in Volts)
Resample I and V to 4 samples to line up with dI and dV
I2 = 0.075, 0.15, 0.35, 0.75
V2 = 790, 810, 830, 850
Divide changes (dI and dV) into current and voltage (I2 and V2)
dI/I2 = 0.6667 0.6667 0.8571 0.6667
dV/V2 = 0.025316 0.024691 0.024096 0.023529
Find ratios of (change in current) / (change in voltage)
R = (dI/I2) / (dV/V2) = 26.333 27.000 35.571 28.333
R should be about 5
From the data supplied, it appears that the core is saturated
https://www.linkedin.com/pulse/knee-point-voltagevk-ps-class-current-transformer-sudhir-tiwari/
Register to Reply 4 comments
