Previous in Forum: Obsolete Word Meanings   Next in Forum: Space Jellyfish
Two-Post Car Lift Lowering Unevenly
10/07/2026 10:01 AM
I picked up a used two post lift recently and noticed that it doesn’t always lower evenly. When I raise a vehicle, both sides seem to come up normally, but when lowering, one side starts moving before the other and I have to stop and reset it.
I checked the hydraulic lines for leaks and didn’t see anything obvious. The cables also look okay, but I haven’t adjusted anything yet.
Could this just be a cable tension or synchronization issue, or is there something else I should check first?
This is the Auto Lift that I have
MalcAndCheese
Pathfinder Tags: Auto-lift lift
Re: Two-Post Car Lift Lowering Unevenly
10/07/2026 10:39 AM
Has the unit been working correctly and this condition has crept in, or has it never worked quite right?
Does this symptom also exhibit when the lift is operated with no load?
In the installation instruction, Section 4.7.2 Step Three details the installation and balance of the cable system. Was a review of this section useful?
In the troubleshooting guide, it advises that you contact manufacturer service/support (section 4.5 of the manual) if experiencing this issue as described. What was the result of that conversation? As you told us, you got this unit secondhand, so the mfgr might (understandably) be reluctant to offer anything useful in your case.
Hazarding a wild guess, sounds like something needs greased. Does she squeak (metal on metal sort of squeak) going up? If yes, that squeak is a scream for grease.
Might be worn sheaves or frayed cable, or main columns not lined up quite right, or… we just need some more.
10/07/2026 11:33 AM
Good points. I haven’t dug into the cable balance or sheaves yet, so I’ll go through that section of the manual and check it unloaded first. I’ll also look for any dry spots or cable wear. Thanks for pointing me in the right direction.
MalcAndCheese
10/07/2026 11:13 PM
My guess is that one of the carriages is binding slightly on the way down, maybe due to a slight alignment problem. If you have someone tap on the cables on the higher side when lowering, one side will make a different pitch, lower, on the side that’s not releasing properly.
As to why it is binding, hopefully something is not bent.
10/08/2026 12:35 AM
It looks like the equalizing chains are either slightly loose or not under equal tension. There should be an eye-bolt style end on both sides to fix each end in place, secured with a nut on top (a double nut and a pin, or a nut with a castle nut and cotter pin)—very much like a forklift mast.
Typically, the side sticking up needs to be checked and adjusted. Follow the procedure in the manual for initial installation. Make sure this is done unloaded and that the arms are equal and level with the safety pins in place. Take out the slack until you just start to see it move.
Comparing one chain to the other should make it fairly easy to see if one has less tension then the other. If the problem only occurs going down, this is most likely the issue; if it happens in both directions, the valve is likely sticking to the cylinder.
Good luck, hope this helps.
Register to Reply 4 comments
Doorman (1); MalcAndCheese (1); miller1277 (1); rwilliams (1)
