A recurring point of confusion in diesel fuel discussions is why a "10 micron" filter will not remove all the water, while a separator bowl half its size sometimes does. The short answer is that particle filtration and water removal are two different physical mechanisms, and the micron number printed on the box only describes the first one.
Three forms of water in diesel
- Dissolved water — held in solution, typically in the tens to low hundreds of ppm depending on temperature and fuel chemistry. No filter removes this; it drops out of solution when temperature falls.
- Emulsified water — droplets roughly 1–25 µm carried in suspension, frequently stabilised by surfactants and by biodiesel content. This is the hard part.
- Free water — droplets large enough (generally above ~100 µm) to settle under gravity given residence time.
Straining vs. coalescing
A conventional element works by straining: fuel passes a porous medium and anything larger than the pore is retained. Applied to water, plain straining only catches droplets that are already large. Emulsified droplets are small and highly deformable, so they squeeze through pores that would stop a rigid particle of the same nominal size.
A coalescing separator adds a second mechanism. Fuel first passes a graded fibre bed with high surface area. Droplets impinge on the fibres, attach, and merge with others. As they grow they shed from the fibres as much larger drops. Once large enough, a second stage — usually a hydrophobic barrier such as a silicone-treated screen or coated media — blocks them while the fuel passes. The coalesced water then falls into a collection bowl under gravity.
Two consequences follow, and both are counterintuitive in the field:
- Flow rate matters as much as micron rating. Coalescing needs residence time. Running a separator well above its rated GPH degrades water removal long before it degrades particle filtration.
- A separator performs better when the fuel has had time to rest. Anything upstream that lets droplets grow — a large tank, a cooler, low velocity piping — reduces the load on the media.
Why finer is not automatically better
There is a persistent belief that a 2 micron element is simply a better 10 micron element. On the suction side of a mechanically governed pump it is usually worse. Restriction climbs as permeability falls, so the lift pump works against higher vacuum, which encourages air entrainment and, in marginal systems, cavitation. Most mechanical injection systems were designed around 10–30 micron protection at the lift pump. Common-rail systems running 1600–2500 bar genuinely need 2–5 micron secondary protection, but they place it on the pressure side, where a piston pump can push through the restriction.
The sound arrangement is staged: a coarse pre-filter / separator on the suction side for water and bulk solids, then a finer pressure-side element sized to the injector tolerance.
For small engines, gensets and marine installs, that suction-side stage is typically a 10 micron coalescing element over a transparent nylon collection bowl with a drain. One specification worth checking before ordering is the port thread: 1/4-19 BSPT (often marked ZG or PT) and 1/4-18 NPT share a nominal size but differ in thread angle and pitch, so they will start by hand and then weep indefinitely. This is the reason most kits ship with both fitting sets — a typical R12T 10 micron fuel water separator assembly, for example, includes four fittings to cover both standards.
Maintenance that actually matters
- Drain the bowl on a schedule derived from observation, not from the calendar. After the first month you will know the accumulation rate for that machine and fuel supply.
- Never judge an element by colour. A dark element can be perfectly serviceable; restriction is the failure criterion.
- Measure restriction rather than guessing it. A vacuum gauge on the suction side tells you more than any visual inspection.
- Replace the bowl O-ring whenever it has taken a compression set. A surprising share of "mysterious air in fuel" complaints end up being the bowl seal rather than the element.
One thing I would like to hear from others: what are you seeing on coalescing media life with high-biodiesel blends? Above roughly B20 the surfactant load seems to shorten service intervals noticeably, and I have not found good published data on it.
