Previous in Forum: Sealant for MMA Mold   Next in Forum: Caption This
8 comments
2021 Blazer Fuel Capacity
10/19/2026 9:59 AM
Every gas pump I use, no matter where in the USA, the fuel automatically stops pumping at about 15.5 to 16 gallon level in the tank. If I pump very slowly, I can add 4 more gallons to the tank. Some gas pump nozzles won't allow me to pump in the extra 4 gallons. The car is supposed to hold 19.4 gallons. The fuel gage reads full before I start pumping in the extra 4 gallons. What is wrong? Where is the extra 4 gallons going and why can't I always be able to pump it in?
Re: 2021 Blazer Fuel Capacity
10/19/2026 1:09 PM
According to this seemingly authoritative site, the 2021 Blazer was not available with a 19.4 U.S. Gallon capacity fuel tank, came with 19.0 or 21.0 gal tank, depending on trim, engine, etc.
Model year 2020 was available with 19.4 gal tank.
See here: https://www.autopadre.com/gas-tank-size/chevrolet-blazer
The reason this matters is that fuel filler pipe and tank vent arrangements vary quite a bit between the model years and tank sizes.
I would suspect that there is an issue with the fuel tank vent… plugged up or pinched… somehow not allowing proper vent of air.
This site has (possibly) a layout diagram of your truck’s fuel filler pipe, and more troubleshooting tips on more complicated solutions:
https://chevyguide.com/how-to-fix-chevy-fuel-tank-vent-problem/
The internet being what it is, there are likely many other sites that have diagrams available.
Regarding “The fuel gage reads full before I start pumping in the extra 4 gallons.” I had a Dodge pickup with a - IIRC - 26 gal tank that read at the gauge as full at 20 gal or so. I dunno if this is a common trait amongst truck type vehicles or not; today I have a Hummer H2 that doesn’t seem to do this.
10/20/2026 12:14 AM
Do you always wait until the fuel light has been on steady for a few miles, then blinking for more miles before getting to the fuel station on the fumes?
Most of us know that can lead to issues by drawing the dregs from the bottom of the tank into the fuel lines.
I would expect to fill up while there was still at least two gallons in the tank, so should not need the full tank capacity.
Pumping extra in takes up the expansion space and can lead to blown fuel tanks. This happened in the past when a manufacturer built tanks with the breather pipe in the wrong location and had to recall vehicles to swap out the tanks.
Madness is all in the mind
Good Answers: 27
10/20/2026 10:10 AM
Most of the automotive fuel tanks have in-line fuel filters, mechanical floats for fuel level measurements and mechanical fuel gauges..
The fuel filter has a builtin cartridge that may already be soaked and partially clogged.. Coupled with the type of the mechanical float used inside the gas tank together with the sluggishness or responsiveness of the mechanical metering used in your fuel gauge when combined with variations in ambient temperatures and the eye parallax may be the reason that causes the differences in your observations...
vsar
10/21/2026 11:32 AM
How do you know how much fuel you have in your tank?
Even if you run your tank empty, you will have some fuel left in the tank, that volume could show up in the manufacturer’s specs. I doubt that the specs of capacity would be usable fuel.
That being said, I can add 2 gallons after shutoff in my 2018 Acadia, and if I try to add a cup of fuel to my 2007 Corvette after shutoff, it splashes out the filler neck.
The back pressure sensors on fuel delivery nozzles are likely in different positions, so interact differently on your filler geometry, making it a tricky job to stuff that extra fuel in.
10/22/2026 9:06 PM
Good point; unless the OP has a very accurate gas gauge or sits at the pump until he runs out of gas, an accurate comparison seems impossible.
10/22/2026 8:54 PM
This explains how the gas pump shutoff works and how it can be defeated.
https://www.youtube.com/watch?v=FRYlTF02A7g
11/05/2026 6:25 PM
On my 2000 Ford F-150, if I turn the nozzle upside-down when filling, I found it will overfill the tank. I discovered this once when I was filling up with the hose stretched across the bed. I suspect it have something to do with the location of the vapor pressure sensing port relative to the fuel flow.
10/24/2026 4:07 AM
Fuel tanks have a shut-off valve which limits over fill which is necessary to allow for expansion in hot weather. Forcing more gas in the tank can lead to a saturated Carbon Canister which can lead to emission problems and the danger of fuel leaks due to internal pressure in the tank.
One piece of missing info in your post. You say that you can only pump 15.5 to 16 galls. before the pump shuts off but you don't say at which point you refuel.
Is your fuel gauge reading empty, is the low fuel light on or what is the gauge reading?
Brave Sir Robin (1); Doorman (1); GM1964 (1); Rixter (2); rwilliams (1); The Wizard (1); vsar (1)
