Previous in Forum: Noiseless Contactors and Relays   Next in Forum: Increased ground fault - NGR
9 comments
Transitioning to the Field of Chemistry
10/25/2026 5:58 AM
Can an electrical engineer, after gaining experience in the chemical industry, shift their career path to become a process engineer or an operations engineer? Or would they need to pursue an additional academic degree? Secondly, is transitioning into the field of chemistry a logical move? after gaining experience in the chemical industry, shift their career path to become a process engineer or an operations engineer? Or would they need to pursue an additional academic degree? Secondly, is transitioning into the field of chemistry a logical move?
Re: Transitioning to the Field of Chemistry
10/25/2026 5:48 PM
Yes, of course one can become a chemical process or operations engineer with an electrical engineering degree. It would help if you also have a Professional Engineer license. The real question is: does the employer and/or government agency require a specific credential for the position? I know some locations do not require any additional certification to operate a system. I know some jobs do require additional certification beyond an Electrical Engineering degree. For instance, here an Electrical Engineering degree is an insufficient credential for wiring a residence for mains power. An Electrician's license is required to legally do this work.
(This is ironic. I'm listening now to a brass ensemble version of Captain Beefheart's "Dropout Boogie." What a perfect accompaniment for this question.)
10/25/2026 5:58 PM
I really don't know how to thank you sir . Your words made me very happy. Can you provide me with some certificates that will strengthen my entry into this field? Because most of the students I ask deny the idea of moving in the first place (I'm still a student about to graduate)
10/25/2026 8:35 PM
Here are some thoughts...
My experience is that you learn what you need to know on the job. As a student, you learn the basics, a little bit about a lot of different things. Once you get a job, you learn a lot about what you need to know.
Follow your interests. If you enjoy your work, you won't have to "work" a day in your life.
10/25/2026 11:06 PM
I have no idea which country, state, or city you or your imagined job is in. So I don't know what certificate, if any, will be required. I do know that your guidance counselor, mentor, or department dean should know which certificates are appropriate for a job. After graduating, I recommend trying to get a Professional Engineer's license in the field studied.
10/25/2026 11:17 PM
Rereading the sparse job description you provide tells me you could be trying to operate an automated bakery, brewery, farm, oil refinery or even a munitions fabrication. Not all of those positions require any license at all. Those that do require different licenses.
10/31/2026 10:06 PM
You close enough , I am preparing to join to petrochemical plant in Saudi Arabia
Good Answers: 27
10/26/2026 11:57 AM
As an electrical engineering student doesn’t make a person an “electrical engineer”, which means that upon completion of your studies you may work in any field depending mostly on your interest, and personal inclination.
Your success is dependent mainly upon your ability to perform and apply in practice whatever you learned in your field of studies
Which means that inclination based transition can easily be achieved while you are still studying.
vsar
10/26/2026 12:05 PM
Yeah, definitely possible, especially in operations. Your electrical engineering background can be useful in a chemical plant, particularly with controls and automation. Process engineering might be harder since some companies prefer chemical engineering graduates, but I’d check the job requirements first before deciding you need another degree.
MalcAndCheese
10/31/2026 10:08 PM
Are professional master’s degrees taken seriously for the purpose of a career change?
ENG_Yami (3); MalcAndCheese (1); redfred (3); Rixter (1); vsar (1)
