Previous in Forum: Bringing Back to Life an Extinct Species: The Dire Wolf
Technical considerations on pulse width stability in commercial picosecond laser systems
10/26/2026 11:35 PM
Hello engineering community,
In commercial aesthetic laser manufacturing, maintaining verifiable short pulse widths (500–750ps window) remains a key challenge during continuous clinical operation.
When transitioning from Q-switched nanosecond Nd:YAG cavity designs to high-peak-power picosecond platforms, optical transmission stability becomes paramount:
1. Optical Delivery: High peak power requires balanced 7-joint articulated optical arms rather than conventional flexible wave-guides to minimize beam profile distortion.
2. Energy Output Benchmarking: In bench testing, single-pulse terminal energy around 1200mJ often shows degradation if resonator cooling and cavity alignment aren't tightly regulated.
We recently compiled an engineering hardware breakdown and delivery checklist comparing articulated arm configurations for clinic environments:
https://mnltlaser.com/product-category/beauty-machines/tattoo-removal-machine/
Curious to hear from other laser optics engineers: What detection threshold do you find most reliable for real-time pulse width verification in high-repetition aesthetic units?
MNLT Laser | Factory-Direct Aesthetic Equipment Manufacturer | https://mnltlaser.com/
Re: Technical considerations on pulse width stability in commercial picosecond laser systems
10/27/2026 9:36 AM
This sounds more like an advertisement for new business. This is an engineering blog. If you have engineering terms you need explained, we can help.
As far as what you posted, an acceptable range of 500 to 750 seems like a very wide tolerance of ±20%. I suspect that will be fine for removing a tattoo. It certainly will not be an accurate timing reference for any pulse-width measurement.
10/27/2026 2:54 PM
I wouldn’t use pulse energy alone to judge pulse width. The energy could stay stable while the pulse duration changes. Are you looking for continuous monitoring during operation or a way to verify pulse width during bench testing?
MalcAndCheese
Good Answers: 299
10/27/2026 5:20 PM
You asked “Are you looking for continuous monitoring during operation or a way to verify pulse width during bench testing?”
Nah, he isn’t looking for any advice at all. I firmly believe that redfred nailed it within his comment #1, our new member is trying to drum up some business.
This type of plea in a spam post is intended to provoke a positive interaction (from the target forum) with the spammer in the hope that more of the product features can be described when he (the OP) responds.
Register to Reply 3 comments
Doorman (1); MalcAndCheese (1); redfred (1)
