Previous in Forum: Bringing Back to Life an Extinct Species: The Dire Wolf
High Viscous Oil Pumping
10/31/2026 3:27 AM
Hi,
for transfer of high viscous Oil 19000 cps@25deg cel which pump will be suitable to transfer around 6 meter and vertical height is 3 meter
Good Answers: 25
Re: High Viscous Oil Pumping
11/03/2026 1:07 PM
More information will get better answers. The following is from a simple google search.
  • Progressive Cavity Pumps: Best overall choice for smooth, non-pulsating flow. They handle high viscosities exceptionally well and are ideal if the fluid contains shears, solids, or requires precise metering.
  • Internal Gear Pumps: Excellent for clean, viscous chemicals, oils, and polymers. They have only two moving parts, are highly reliable, and provide a steady, continuous flow.
  • Lobe Pumps: Best choice for hygienic or food-grade fluids. They are widely used for thick food products (like creams, pastes, and syrups) because they do not shear the fluid and are easy to clean in place (CIP).
  • Air-Operated Double Diaphragm (AODD) Pumps: Best for utility, portability, or hazardous environments. They run on compressed air and can handle 19,000 cPs, though you must oversize the pump and use larger ports/hoses to prevent cavitation.
Troy
Reply to Forum Thread
