Previous in Forum: Air Compressor Pressure Drops During Operation
Vena Contanta - Valves
11/05/2026 8:54 AM
Hi to all,
Based on the table below, is the pressure drop across a ball valve or a gate valve greater than that across a globe valve?
My question is: How is this possible, considering that, due to its geometry, I would expect a globe valve to create lower-pressure points than a gate valve or a ball valve, whereas a fully open gate valve has a much smaller effect on the pipe's cross-sectional area?
Pathfinder Tags: valves
Re: Vena Contracta- Valves
11/05/2026 2:18 PM
Confusion abounds.
Is the first paragraph a statement or question? Seems to be a statement of condition, terminated with a mark of interrogation.
The second paragraph is identified as a question, yet seems to contain stated (non-conditional) facts.
Having reviewed the diagram several times, I see no reference therein to gate valve performance, yet the question seems to revolve around the comparative performance of a gate valve against… something else, I guess.
And, I believe the correct thread title is probably vena contracta (Ah, never mind; I find that the CR4 spellchecker autocorrects “contracta”, this is the likely trouble)
Re: Vena Contanta - Valves
11/08/2026 10:05 AM
I think you're mis-reading the graph. I find it confusing myself.
If you look at the left side, it shows inlet pressure. The right side shows outlet pressure, and the red line (Ball Valve) shows that the outlet pressure is higher than the blue line (Globe Valve).
The 'Permanent Pressure Loss' labels don't make sense to me. I think the graph is labelled incorrectly.
11/08/2026 2:23 PM
The graph clearly shows the pressure drop of a ball valve is much less than a globe valve.
(permanent pressure drop)
The graph shows the relative pressure profile down the length of the pipe, due to the influence of the typical valve geometry
You might use that to determine where you might place sensing points for a pitot or a flow orifice, or simple pressure gauge.
11/08/2026 2:37 PM
The ball or butterfly valve has higher pressure output than the globe valve because the water has a straight path through it whereas the globe valve makes the water change directions internally which makes it loose pressure after it.
11/09/2026 12:01 AM
I doubt the accuracy of the red graph line, especially with regard to a ball valve. The ball valves I'm familiar with, when completely open, have a completely unrestricted flow through a full cylindrical opening, so should have essentially zero pressure drop.
If the graph represents the flow through a partially open valve, that fact should be clearly stated.
11/09/2026 8:26 PM
There is no scale on the pressure, so we have no absolute reference to make a judgement on this. It just shows relative pressures.
There are standard and full port ball valve constructions. Either one will appear as a disturbance in the flow path, even wide open, so the permanent pressure drop will never be zero. A standard port valve was probably used to develop the relative comparison
Even the connections from the valve body to the piping are never perfectly smooth, and will provide permanent pressure drops dependent on the technology.
11/10/2026 9:50 PM
The graph does show that the net pressure drop across the valve is lower for ball and gate than globe.
The graph is also showing that the peak pressure drop (before revovery) is greater for a ball or gate than a globe.
Because a ball or gate valve generally presents only a small smooth reduction in cross section with a gradual return, without significant change in direction, most of the change in pressure is a conversion of static pressure into kinetic energy and then back to static pressure. Most of the energy is recovered leading to a smaller overall drop in pressure.
For a globe valve, there is still a restriction and some static pressure is converted to kinetic and (of that portion, largely) back to static pressure again, but it is not a smooth gradual mostly-straight path. The path is more torturous in a globe valve so a significant component of the pressure drop is turbulent and mostly not recovered back to static pressure. The velocity does not reach values as high as for a ball or gate valve, so the pressure does not drop as low at the minima, but because more is unrecovered to statuc pressure (instead being largely converted to heat) the net pressure drop is greated for a globe valve.
The visual is basically correct, though it could be made less confusing.
Register to Reply 7 comments
dkwarner (1); Doorman (1); rwilliams (2); StandardsGuy (1); steve45 (1); truth is not a compromise (1)
