Previous in Forum: Sugar mill calculations and settings?   Next in Forum: Machines For Use In Indian Enviornment
Refrigerated CO2 Incubator w/Photoperiod
12/18/2007 5:41 PM
Hello All,
I am new in the group. I begin with a question.
I need to develop a refrigerated CO2 incubator with photoperiod (programming lights) from a normal refrigerated incubator. Have any suggestions?.
Please do not respond me that I must Purchase one, we are short of budget and this is the cheaper alternative.
Best regards,
Esteban
Good Answers: 11
Re: Refrigerated CO2 Incubator w/Photoperiod
12/20/2007 8:56 AM
I'm afraid that the answer is then going to require what types of materials you have on hand. It's not going to be possible to suggest anything unless we know where you are starting from.
Eric
Canada - Member - New Member
Good Answers: 11
12/20/2007 9:09 AM
How complex is your lighting period?
Can you use a standard timer sold in hardware stores?
Peru - Member - New Member Engineering Fields - Biomedical Engineering - New Member Popular Science - Genetics - New Member Fans of Old Computers - Commodore 64 - New Member
12/20/2007 11:23 AM
Hi Esteban
What I want is that (build, modify or buy) one with those characteristics.
An incubator of CO2 contains: A water jacket. A thermal resistance within the jacket. A temperature controller. A sensor CO2-there are two types of thermal IR or driver. A controlling entry of CO2, which includes a solenoid and digital card. Pressure gauge ball of CO2. Ball CO2, etc.
Usually these teams are working at 37°C - 32°C, non-refrigerated (+5°C ambient temperature).
There chilled working between 10°C to 25°C, used for growth of ballots or parasites type Leishmaniasis.
I recommend not build, and you will leave more expensive than buying it.
Modify one, if you can, your problem is that if you have experience and know the dangers of CO2!
And buy it is the most optimal have several brands: Form Sci, Fisher, J. T. Baker, Nuaire.
________________________________________________________________________
Lo que entiendo es que tú quieres (construir, modificar o comprar) una con esas características.
Una incubadora de CO2 se conforma de: Una chaqueta de agua. Una resistencia térmica dentro de la chaqueta. Un controlador de temperatura. Un sensor de CO2 – hay de dos tipos IR o conductor termal. Un control de entrada de CO2, que incluye un solenoide y tarjeta digital. Manómetro del balón de CO2. Balón de CO2, etc.
Usualmente estos equipos trabajan a 37ºC – 32ºC, los no refrigerados (+5ºC temperatura ambiental).
Hay refrigerados que trabajan entre 17ºC a 25ºC, usados para crecimiento de cedulas o parásitos tipo Leishmaniasis.
No te recomiendo construir, ya que te va a salir mas caro que comprarlo.
Modificar uno, si se puede, ¡el problema es que si tienes experiencia y sabes los peligros de CO2!
Y comprarlo es lo más óptimo tienes varias marcas Forma Sci, Fisher, J.T.Baker, Nuaire.
Tomás
We must understand the things like are and not to try that they are as we want.
12/20/2007 11:58 AM
Apreciado Tomás y Grupo.Gracias por el apoyo. Tal como lo describí en el Post, mi intención es adquirir una incubadora refrigerada tal como (http://www.polekolab.com/index.php5?products&cooled_incubators&ilw_53_1) y luego realizar yo la adaptación del sistema de inyección de CO2. Tengo muy claro que construir una desde cero no es una alternativa, por esto mi inteción es ADAPTAR una. La situación del fotoperiodo es un problema ya que cuando el sistema está con luz la temperatura interior sube casi 12ºC. He contactado con un proveedor de fibra óptica para iluminar el interior y no incrementar la temperatura.
Les agradeceré me apoyen con recomendaciones del sistema de inyección de CO2.
Dear Group,
many thanks for the support. As I told previously, My aim is to purchase and ADAPT with CO2 a refrigerated incubator like (http://www.polekolab.com/index.php5?products&cooled_incubators&ilw_53_1), not build one from scracth. I need support with this issue. The photoperiod when the lights are ON raise the interior temperature in almost 12ºC. I am decided to use optic fiber to transmit cold light from a exterior source.
I am open to hear your tips.
12/20/2007 1:47 PM
I am at the University Cayetano Herredia, an incubator vertical type refrigerator 15 p3 which is the gateway 8 fluorescent willing 4 above and 4 below.
Ballasts and arancadores are outside and are in the upper portion control, and an acrylic tubes separates the compartment samples, send mail to send a photo before the weekend.
Tomas
Incubator Upright mark Precision SCI, Model P3696, this is what you need.
Tengo en la Universidad Cayetano Herredia, una incubadora vertical tipo refrigerador de 15 p3 que tiene en la puerta 8 fluorescente dispuestos 4 superiores y 4 inferiores. Los balastros y arancadores son externos y estan en la parte de control superior, y un acrilico separa los tubos del compartimiento de muestras, mandame tu correo para mandarte una foto antes de fin de semana.
Tomás
Incubadora Vertical, marca Precision SCI, Modelo P3696, esta es la que tu necesitas.
12/20/2007 1:58 PM
The only thing I can recommend is that you need to carefully gauge CO2 ball of gas, it must be specifically for CO2 system heater, looking at AGA they have a model that you can serve.
And if you want to control CO2 within the chamber, there are two types of monitors drivers an IR is recommended is more accurate, and the driver thermal classic on the Internet find.
Lo único que te puedo recomendar es que tengas cuidado con el manómetro de CO2 del balón del gas, debe de ser específicamente para CO2 con sistema calefactor, busca en AGA ellos tienen un modelo que te puede servir.
Y si quieres controlar el CO2 dentro de la cámara, hay dos tipos de monitores controladores uno de IR que es el recomendado es mas preciso, y el conductor termal el clásico, en Internet encuentras.
Tomas
Register to Reply 6 comments
ca1ic0cat (1); estebanoliveros (1); gigaconcept.com (1); Grage Tesla (3)
