Previous in Forum: Concrete Roofs: Uncontrollable Leaks!   Next in Forum: switch with 10mA
24V EGR valves
12/24/2007 10:49 PM
Kindly let me know any manufacture who Manufactures EGR valves operating directly on 24V system. M/s Pierburg is saying it is manufacturing only 12V EGR valves.
Regards,
Raghavendra K
Technical Fields - Education - New Member Technical Fields - Technical Writing - New Member
Re: 24V EGR valves
12/26/2007 10:26 AM
You may add a resistor for 12 V drop.
On Valve coil terminals it would be = 24 V (Power Supply) - I (coil current) * R (Ohms) = 12 V
Re: 24V EGR valves
12/26/2007 1:00 PM
Probably alot cheaper to go with the flow and use the 12 volt version of the EGR with on of the resistor methods to reduce the voltage to 12 volts.
IF you have 24 volt supply DC:
then 1 resistor 'in series' with the presumed 1 amp EGR can be 12 ohms. Then V = IR = 1 * 12 = 12 volt drop on resistor leaving `12 volts left for the EGR valve. Probably best since this arrangement only uses power when the EGR is activated (or coil energized). Use 12 watt resistor type @ 12 ohms since Watts = V I
Or you could use a resistor tree but its not necessary, requires 2 resistors, and uses power constantly too.
Peace begets Synergy which begets Progress!
Re: 24V EGR valves
12/26/2007 1:05 PM
Don't forget to use a (presuming 1amp) fuse in series with EGR for safety .
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
