Previous in Forum: Fabric with Water Barrier   Next in Forum: Voltage Calculation of Electric Element
12 comments
CD Media Sheets
12/27/2007 2:30 PM
Hello all,
I am in a need of a rectangular (~2 feet x ~3 feet) media sheet, made od the same material as CDs/DVDs that we use on daily basis. Any idea where I could purchase it? It is intended for a personal artistic project. Thank you.
Regards,
Dex
Pathfinder Tags: CD material media sheet
Good Answers: 918
Re: CD Media Sheets
12/27/2007 2:54 PM
It is called Tyvec. It is also used in bulk to wrap the outer wall of houses as a water and wind barrier. Try your local home hardware and lumber stores (Lowe's and Home Depot, etc.).
Re: CD Media Sheets
12/27/2007 3:13 PM
Hi Hero,
Thanks for your reply, but I am not sure I explained well what I'm looking for. A media sheet should be made of the same glossy/shiny/smooth/rigid material as a CD. The goal is to get a raibow colors effect when lit (only a side where CD is burnt would give colorful effect); what I'm looking for is basically large rectangular CD (that I would later cut into irregular-shaped pieces).
Regards,
Dex
Good Answers: 918
Re: CD Media Sheets
12/27/2007 3:37 PM
The prismatic effect is from precision etching into the plastic CD. I don't know of an off-the-shelf equivalent.
Sounds like an interesting project.
Re: CD Media Sheets
12/28/2007 1:22 PM
Isnt the prismatic effect due to the diffrraction grating etched on the CD?
Re: CD Media Sheets
12/27/2007 5:03 PM
Correct, the closest cost effective material that I am aware of is going to be .065" polycarbonate sheet. That material is readily available. Aluminum backed circular etched is a whole 'nother problem.
cr3
Re: CD Media Sheets
12/27/2007 11:17 PM
The Material: "made od the same material as CDs/DVDs that we use on daily basis."
The Plastic Material Is
"I am in a need of a rectangular (~2 feet x ~3 feet) media sheet,"
XL10 Polycarbonate Lexan Sheet
Ever hear of Google.com which should be a constant companion of every good engineer.
BTW Tyvec sheeting is a wrapping plastic and is the result of misinterpreting your request.
Re: CD Media Sheets
12/28/2007 6:31 AM
Finely etched in circular pattern metal foil???? old Lazer Disc is 12" across. Please post if you find material you are looking for.
Fans of Old Computers - Commodore 64 - New Member United States - US - Statue of Liberty - New Member Engineering Fields - Control Engineering - Process Control Engineer
Re: CD Media Sheets
12/28/2007 1:27 PM
CD's are not stamped out of a larger sheet, but are injection molded so there is nothing equivalent. You have to buy a sheet of plastic and stick something onto it, and cut it to size. Google holographic stickers or sheets.
Look here for some holographic sheets you could adhere to an acrylic base. (Cheaper than lexan). http://www.asp-rocketry.com/store/category.cfm?Category=205
It is impossible to defeat a fool in an argument, he wil bring you down to his level and beat you with experience.
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
Re: CD Media Sheets
12/28/2007 3:11 PM
I find it interesting how frequently so many of us interpret seemingly straightforward questions in completely different ways. To me, it seems like AccuDave's answer hit the nail right on the head, although it's very different from the rest of the answers.
To the original poster ... is AccuDave's website the solution to your problem?
Re: CD Media Sheets
12/28/2007 3:24 PM
My (very) original idea was to have a clear glass that would refract (not reflect) the spot light in a prismatic way, either by using special glass (any ideas?), or by coating "normal" glass.
Then the plan was alternated toward looking for a rectangular CD media sheet that would reflect (and not refract) the light into different colors.
Sticking hologramic decorative sheets to the piece of plastic would probably produce different colors in reflection, but differs significantly from the (very) original idea (refracting light through clear glass) - I still beleive it's possible to do it somehow. If it turns out it's impossible, then I will consider AccuDave's idea.
Thank you all for giving suggestions. Regards, Dex
Re: CD Media Sheets
12/30/2007 12:18 AM
There is a factory near me that commercially produces music CD's. WEA Mfg., Olyphant, Pa.
http://goliath.ecnext.com/coms2/product-compint-0000108306-page.html
Check this link and give them a call, who knows....they might sell you a damaged piece of raw material !
Unless you're the lead dog on the sled, the view is always the same....
Good Answers: 94
Re: CD Media Sheets
01/02/2008 5:42 AM
Have you looked at the projector lamps used for disco lighting? They use (at least they did when I was involved with them years ago) glass disks to create light patterns. The disks had either colours or moulded patterns to refract the light. I think I still have some of these disks kicking around at home somewhere.
Register to Reply 12 comments
AccuDave (1); Anonymous Hero (2); Anonymous Poster (1); Dex (2); Nigh (1); Out of Box Experience (1); Self Thinker (1); Sniccus (1); Stirling Stan (1); TexasCharley (1)
