Previous in Forum: Oil Storage Tanks   Next in Forum: Calculating propeller drag
Induction Hardening
12/28/2007 8:35 AM
I am new to this induction hardening. I have a problem ck45 shaft when i taken for induction hardening. I Observed face crack in ck45 shat, Pls help me to solve this problem it is medium frequency machine.
Good Answers: 243
Re: Induction Hardening
12/29/2007 6:07 PM
hello guest.
There are several possible means of cracking this grade.
A prior existing seam is quite likely if insufficient/ no stock removal has been taken off the original steel bar.
Look for a layer of different 'texture' just under the OD of the failure surface. That will likely be decarb from rolling in the bar mill and is testimony that the seam prexisted the crack.
If no such visual evidence presents, then a quench crack is the likely explanation. Many factors including tool marks, severe change of section, improper quenchant makeup (too much Water/insufficient/improper polymer) as well as improper operating parameters for grade.
To Characterize the failure to solve the problem, look at the fracture surface
milo
Good Answers: 25
12/30/2007 7:05 AM
There could be following reasons:- 1.Sharp corners at different diameters. 2.Incorrect quenching process. 3.Basic matterial may not suitable for induction hardening.Do the chemical tests for raw matterial. 4.Improper temperature in heating of shaft.
Good Answers: 243
12/30/2007 12:29 PM
Not to put too fine a point on this, but ck45 is intended for quenching and tempering. If the comment is that this specific lot of material is not ck 45 and thus not able to be successfully induction treated, I agree; if the comment was that ck45 is not induction hardenable, my 30+ years in the steel business tells me to strongly disagree.
Here's the chemical analysis per din 1652-4:
Chemical Composition Grade Ck45 WNr. 1.1191 Standard DIN 1652-4 Country Germany Heat Analysis Element Symbol Min. Max. Carbon C 0.42 0.5 Manganese Mn 0.5 0.8 Phosphorus P 0.035 Silicon Si 0.4 Sulfur S 0.03
milo
Good Answers: 25
12/31/2007 4:29 AM
It seems my comments are not properly understood.I am not questioning suitablity of ck45 (DIN Std) for induction hardening. I asked you to check confirmablity of material used by you to this standard. Also please take care of the other points I have raised.
04/23/2009 11:41 AM
dear sir, phenomenon of face crack comes into picture if the face is getting over heated /there is uneven depth distribution near the face,or uneven quenching ie external surface is rapidly cooled where as internal core is still hot to provide differential contraction rates,also increase in quenching time aftr hardening can solve the problem along with increase of polymer concentration
11/26/2009 4:46 AM
DEAR SIR
YOU MUST USE AQUOES SOLUTION OF POLYMERIC MATERIAL IN WATER TO QUENCHING.
0098411 4296279
BEST REGARDS
EMANI
07/26/2010 7:33 AM
pls check the various process parameters like gap between the induction coil and workpiece , current etc.
Anonymous Poster (3); Milo (2); suresh sharma (2)
You might be interested in: Induction Heaters, Tool Steels, AC Motors
