I am facing a problem of high sterntube bearing temperature, where for lubrication and water ingress problem header tank with omd 113 oil is fitted. which is at a height more than sea water level so a pressure head can be created. I am having a header tank and the supply line for stern tube is from the bottom and the return line is from top. please suggest if there will be circulation or not and if it is there ,will i be able to see oil circulation back to tank as i am having a transparent pipe on return line at the top of tank. please suggest me pipe diameter of supply and return pipe also, will they be equal or supply more than return line.
