Previous in Forum: piston   Next in Forum: Surface Waviness
Use of LapJoint Flanges on U Stamp Pressure Vessels
01/08/2008 4:02 AM
To interconnect a stainless steel ducting system SS304L/SS316L , we are using Industy Standard Class 75 & Class 125LW Lap joint flanges.
Question
To connect this ducting to the pressure vessels, may flanges , Class 125LW, be used as Lap Joint flanges with nominal diameters of 24"- 28"- 36" and 48" on the pressure vessels itself.
Design code ASME sect VIII div.1 / U-stamp, design pressure max 22psi / min. FV
Material of flanges SA105N - Hot Dip Galvanized with Expoxy Coating
The basic materials on the vessels are Nickel201 / AISI 904L / AISI 304L
Pathfinder Tags: ASME VIII div.1 LJ Flanges
Re: Use of LapJoint Flanges on U Stamp Pressure Vessels
01/09/2008 11:54 AM
The flanges you intend to use are not accepted for use without the Vessel Designer proving they're adequate through Code Calculations. Otherwise you would need to use ASME B16.47 flanges to avoid the calculations.
Mark
01/12/2008 4:46 PM
A. According to ASME code Section VIII, Division 1, the use of lap joint flange (VAN STONE flange) is accepted per Mandatory Appendix 2, Fig. 2.4(1). But a vessel designer must proceed the required design.
B. For LWN flanges, the ASME codes don't imply any mention to those type of flanges, but we -as a designers- used them without any limitations.
C. For lap joint flange (composed from loose ring or flange and stub end) :
1. For a pressure vessel fabricated from carbon steel, you can use SA105 lap joint flange, where the flange (loose ring) is Hot Dipped Galvanized (or may be stainless steel), but the stub end which welded to the vessel shall be CS without galvanizing, because you are not allowed to weld any part after its galvanization.
2. For a pressure vessel fabricated from Nickel201, AISI 904L or AISI 304L, the flange (loose ring) can made from these materials or any other material, but the stub end which welded to the vessel shall be made from the same type and grade of shell material: Nickel201, AISI 904L or AISI 304L respectively.
Register to Reply 2 comments
