Previous in Forum: degausing   Next in Forum: ASTM d 1816
Choosing Between PWM Chip and Microcontroller to Generate PWM Waveform?
01/08/2008 7:27 AM
hi, I wonder if either a PWM chip or microcontroller is easier to generate sinusoidal PWM waveform?
I have written a program that produces PWM waveform in MATLAB, but I don't know if i can connect it to a microcontroller to generate exactly the same waveform as in MATLAB? If so, how can it be done?
thank you.
Re: Choosing Between PWM Chip and Microcontroller to Generate PWM Waveform?
01/08/2008 3:59 PM
It depends on the frequencies you require.
I believe there are some good waveform generator chips which may be a more appropriate starting point.
A micro-controller could well be a bit slow? Have you got development kit for a microcontroller?
01/09/2008 7:26 AM
the frequency i require is 50hz.i am not sure what is the developement kit for microcontroller. by the way, how to connect a MATLAB program to a microcontroller?
01/09/2008 7:59 AM
No idea!...
If I wanted 50hz, I'd just use mains frequency via a transformer...
Where are you? What is your mains frequency? What do you want to do with the 50 hz...?
01/10/2008 7:51 AM
i am from singapore.i need 50hz PWM waveform for my induction motor
