Previous in Forum: Ignition problem   Next in Forum: temp of clear light bulb
semi-permanent floor system
01/19/2008 7:44 PM
I'm looking for ideas for a "semi-permanent" floor system in an area of a pole barn. As of now it is just a dirt floor with 2"X2'X8' ridgid foam insulation buried vertically on the exterior perimitter walls. I would love to someday put radiant floor heating in or, at the very least, some plumbing for a small bath-thus the reason for "semi-permanent." I plan to use the area as a work shop and have no real heavy weight machinery or needs for the area. Just for putzing around. I'll definitly need a vapor barrier designed into it.
I know that you believe that you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant
Popular Science - Cosmology - New Member Popular Science - Paleontology - New Member Popular Science - Weaponology - New Member Popular Science - Evolution - New Member Popular Science - Genetics - New Member Popular Science - Biology - New Member
Location: The Nevernever as much as possible, Earth when I have no choice.
Good Answers: 11
Re: semi-permanent floor system
01/20/2008 11:14 PM
Dear Wbsterritt, First level the dirt floor as much as practical. Then build a short (4 inch) pier and joist frame, like building a deck, only on the ground. Before actual assembly lay plastic sheeting for vapor barrier. After assembly of "mini" deck frame lay flexible PVC tubing between joists. This gives you radiant heating. Make the deck panels removable (like the floor in a computer room used to be) and you can route plumbing for your bath.
Regards Dragon
Ignorance is the beginning of knowledge. Heresy is the beginning of wisdom. The ignorant heretic is the wisest of all.
Good Answers: 94
01/21/2008 11:46 AM
In my workshop I levelled the floor, used some soft sand to help fill some of the unevenness, then laid 8x4 sheets of 2" rigid foam insulation with a tongue & groove 18mm chipboard floor on top. It's firm enough to stand a fair bit of weight & stays reasonably warm.
01/22/2008 11:17 AM
I have asphalt in my garage, and it seems to work ok. To move heavy things around, such as with an engine hoist, I went to the local metal scrapyard and got some steel plates I can place wherever I need to go, otherwise my steel casters dig right in (bear in mind, Im usually moving 600-700 lbs on 3" dia wheels). If I ever decide to rip it up, I know I can probably strip it all out in an afternoon with some basic tools. For a small area like the one you are describing, this might be a cost and time effective route for you to go, as you can easily have it done in a few hours.
Avery Montembeault
Register to Reply 3 comments
Anonymous Poster (1); Dragonsfarm (1); Nigh (1)
