I am looking for an answer about static protective devices. I have had installations with inductive protective relays on 13.8kv. We performed routine cleaning and calibration every 2years on these devices. We had 480v breakers with old analog protective devices. I do not believe they were ever tested and calibrated. When I sent them in for tests they were found to have 4 to 6 times more instantaneous fault current then the indicated set point. We switched the 480v out with static Joslyn units.
I am at a facility now that has all static trip devices and do not have an idea as to how frequently they should be checked for calibration. We have static devices on the 13.8kv and 480v.
The facility is 10 years old and the breakers and switchgear have never been lubricated or had their protective relays calibrated.
Can anyone help. Do static units drift with time like the older analog. Are we in danger.
