Previous in Forum: Box Threads   Next in Forum: What is the effect of continueous inlet pressure flactuation in steam turbine?
Teflon Seal Prob
01/25/2008 12:47 PM
Dear All,
We have Injection Molding machine Its tonnage drop problem facing so we remove tie bar & check Teflon Seal. Some seal found damage so we remove old & try to insert new. but they are entry in there position. In factory manual they mention just heat seal in oil near 150 degree cel. so we do that than our seal expand & also enter in there positing but after cooled seal does not contrast in original position. so seal is loose fitted. still our work is stop any body suggest me that our procedure is right or wrong or any other way to inserting teflon seal
TARGET - Where many stop thinking, some start from there. Tenacity to get target helps to WIN.
Re: Teflon Seal Prob
01/26/2008 10:11 AM
All the Teflon seals we put in we heat with very hot water. I would try 150 degree Fahrenheit,
