Previous in Forum: Problem : Short of one wire in a cable, how to fix it?   Next in Forum: power distribution blocks
9 comments
Lead Acid Batteries
01/26/2008 2:00 AM
Hello Guys
Could u pls. tell the better preventive maintenance schedule of the Lead Acid batteries used in the Forklist and UPS's. Whic one is best device to check the remaining useful life of the batteries.
Thanks to all
Re: Lead Acid Batteries
01/26/2008 8:40 AM
For Vented or Sealed lead acid batteies, a cost effective and simple battery tester -YUASA Battery Tester- will do the job.
01/26/2008 11:18 PM
Take a look at the thread power problem, particularly post-93. There's a lot of information about batteries in this discussion. You might try asking this question on that forum, elnav is quite knowledgeable in this area. I will include the address in case you can't find it going to the forums. Also you might want to research a anti-sulfation charger. Good luck
http://cr4.globalspec.com/thread/16468#newcomments
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man" George Shaw
Good Answers: 39
01/27/2008 3:16 AM
Check out www.midtronics.com They invented a real neat technique using capacitance testing to measure battery condition.
The Yuasa battery tester appears to be a house branded version of th eMidtronics design.
Elnav
01/27/2008 8:06 AM
Hi the best thing to your battery is making test on it periodically, also put it in low temperature is not more than 25 ºC while the more temperature the low battery life
Good Answers: 39
01/27/2008 1:23 PM
Himanish wrote: Could u pls. tell the better preventive maintenance schedule of the Lead Acid batteries used in the Forklist and UPS's.
REPLY: You ask a question for which the answers have often taken a complete book to write: Better than what? How do you do preventative maintenance right now? Are you plant maintenance staff or maybe the manager of such a department? Or are you representing a company selling a product or service, for this application? Forklifts use deep cycle traction batteries. UPS use batteries that can withstand deep diascharge but at much lower current rates. Some UPS must have excellent long term storage characteristics and extremely low self discharge.
This is completely different from the daily heavy use for traction motors in fork lifts. Properly conducted maintenance involves very different parameters for each type.
The advice to keep batteries cool below 25C doesn't help much if you live in low latitude tropical climates with daily ambient temps well above 25C and a work environment even higher than that. Temperature compensation techniques must be used in such cases. There simply isn't room enough to write a complete answer to your question here. If the battery manufacturers recommendation is not sufficient for your purposes, contact me off line. I earn my living as a consultant.
Elnav
Good Answers: 12
01/28/2008 12:08 AM
Please visit our company web site for free downloads: www.hbl.in
We do not make Forklift (Traction) Batteries. Exide, Yuasa make them you can download free datas.
Subramanyam
01/28/2008 8:32 AM
SIMPLY: Charge lead acids immediately after use,
This is to prevent sulfate from hardening on the plates (after awhile this creates shorts between plates making that specific cell bad, that in turn degrades the performance).
Check fluid levels frequently
Peace begets Synergy which begets Progress!
Good Answers: 42
02/01/2008 9:59 AM
The Lead acid battery for Fork lifts and battery trucks need special and regular care to ensure long life. Normally the manufacturers provide the maintenance schedule which should be followed strictly.
The following important points are to be ensured.
1. The initial charging of the battery should be done as per the instruction of the manufacturer if the battery is received with out initial charge from the factory. If the battery has come with charged condition then a boost charge may be given before connecting to the fork lift.
2. The battery should be recharged regularly as per recharging schedule, before it get dis charged to the recommended low level. It is always better to recharge the battery after specified hours of running of the forklift with out waiting for the battery to run down.
3. The battery terminals should be kept clean with out allowing sulphation and connection should be rigid not to allow sparks and damage.Connections should be checked regularly.
4. Ensure that the charging system of the fork lifter is working properly.
5.The acid level, specific gravity and voltage of the individual cell must be checked regularly to ensure timely correction. One damaged cell can spoil the complete battery.
For UPS the battery must be connected with automatic float charging system,The proper working of the system should be ensured. Regular periodical maintenance as per schedule should be carried out. If it is maintenance free sealed batteries then the automatic float charging system should be checked for proper functioning and batteries should be kept clean.
Request for Enlistment as a Registered Supplier
06/23/2008 6:50 AM
Dear Sir,
We are pleased to introduce ourselves as a leading manufacturer in India . We are manufacturer of Antimonial Lead Ingots & Wire, Solder Wire & Stick (Bar), R.C.Solder Wire, White Metal, Lead base items i.e. Lead Sheet, Lead Pipe(Tube), Lead Seal, Lead Wool, Lead Wire, Lead Stick etc. and also Lead & Tin base Alloys.
We are registered with NSIC, Directorate of Industries, DGQA & O. F. Varangaon. We regularly supply our products to various Ordnance Factories, Railway Dept., Public Health Engineering Dept., and other many Govt., semi Govt., & reputed private companies . Therefore, we would like to enlist our name to your end as a Registered Supplier.
Please, take necessary action about it and send us your Registration Certificate at an earliest.
Awaiting your suitable response.
Thanking you.
Yours faithfully,
For Malti Metal Industries,
Vinod Kumar Gour
Materials Manager.
Register to Reply 9 comments
Anonymous Poster (2); elnav (2); kvsubramanyam (1); melshamy (1); TRIPLEBATTERYLIFE (1); V.I.Abraham (1); YWROADRUNNER (1)
