Every Photon Matters
Jan. 25, 2008 -- A new engine
with no moving parts has been shown to convert waste heat and
concentrated solar energy into electricity better than conventional
solar panels.
The invention could lead to electricity generators ranging in size
from the very large, such as those used by utility companies, to the
very small -- such as those that tap body heat to generate power for
personal electronics.
Because the conversion rate is so high, the technology could make solar energy cheap enough to compete with fossil fuels.
"It's not just the dependence on oil, it's the whole challenge of
providing energy that is sustainable without destroying the
environment," said nuclear engineer Lonnie Johnson, founder of Johnson
Research and Development and Johnson Electro-mechanical Systems, both in Atlanta.
Johnson is funding his research with money he made by inventing the
super soaker squirt gun. His new, somewhat less cavalier, invention is
called the Johnson Thermo-Electrochemical Conversion System.
The original goal, in part, was to address a common problem with
energy: When it's generated -- by gas, coal, battery, or other means --
much is wasted into thin air. In fact, in the United States alone, the
amount of energy lost is more than the energy consumed by the entire
country of Japan.
Johnson's engine captures that heat and turns it into useful power.
It's called an engine because it's based on thermodynamic principals
that exist in mechanical engines, such as those that power automobiles.
In a car engine,
moving pistons and rods compress gas at low temperatures and expand it
at high temperatures to convert heat energy to mechanical energy to
drive the
In Johnson's energy-converting system, electrodes on a thin membrane
compress hydrogen gas at low temperatures and expand it at high
temperatures. The pressure forces hydrogen ions through the membrane,
stripping off electrons to generate power.
And although the system uses hydrogen, it does not burn it the way a
hydrogen fuel cell would. It simply re-circulates the same quantity
over and over.
"This is a whole new way of converting temperature differences to
electricity that has never existed before," said Paul Werbos, program
director for power, control and adaptive networks at the National Science Foundation in Arlington, VA..
If it works, it could be far more efficient than the best solar cells, which convert about 30 percent of sunlight into energy.
Johnson's system could reach 60 percent. But for that to happen, it
needs to operate with very high temperatures, upwards of 1,400 degrees
Fahrenheit (800 C).
Achieving that temperature will be a challenge, said Werbos.
"They will need new membranes and electrodes, and they will have to
prove that they are handling the hydrogen correctly," said Werbos.
So far, the researchers have built a device that works at 392
degrees F. Johnson hopes to have demonstration model working at 1,400
degrees in a year to 18 months.
Above is a copy of a recent discovery news article about a new heat to electricity conversion. It sounds great and would absolutely be wonderful but what may stop this in it's tracks? Sounds like other great inventions that seem to have disappeared over the years. Where will this one go?
