Can you explain your request in more detail? Are you looking for a method for testing the quality of a weld. Or, are you looking for how to specify a full-strength weld? Or, are you asking about full penetration welds?
I want to know whether a joint made by welding has enough strength to bear the load under which it will be subjected or it will fail. There must be some calculations for this.I mean minimum thickness of weld for a particular load which will be put on this welded joint.
Can you please submit a drawing for the joint to indicate all dimensions, applied forces, type of materials, and joint design details to clear if there are a fillet and/or groove welds to calculate the throat of weld. A stress analysis must be carried out to indicate the shear, longitudinal, twist, and compressive stresses, to be compared with allowable stresses of material.
Can you please submit a drawing for the joint to indicate all dimensions, applied forces, and type of materials. Also, joint design details are required to clear if there are a fillet and/or groove welds. A stress analysis must be carried out to indicate the shear, longitudinal, twist, and compressive stresses, to be compared with allowable stresses.
You wil Need to either do a destructive test i.e checking the force of the weld or X ray or ultrasonic testing using known good parts to create a "weld signature " to comapre against .But first you need a bench mark of what a good weld is .
There are tons of places that delve into the different types of welding joints. ASME, AWS API etc.As a general rule one should have root to face thickness of at least the thinner of the 2 pcs. to be welded not counting weld reinforcement. This will work for most types of weld joints. Hope this helps.
