Previous in Forum: Welding Engineering Field, need help from welding engineer and ex engineer   Next in Forum: Exhaustgas detection in coolant
8 comments
motor speed reduction
01/31/2008 12:10 PM
I have a motor three phase 1/4 Hp and out put speed is 850 RMP
after 3:1 gear ration i am making operation of (surface grinder machine)travel at very sharp inch about 3 to 5 mm.
my need is around 0.5 to 1mm travel.
there is no space for further gear reduction.
i don't want to use VFD drive.
is there any another method for RPM reduction. if yes pls support.
Else i am working on same after this post i make 12 HRS sleep get fresh and work for another 8 HRS and post on same forum.what i did and how i solve problem.
Hope at least some one help me !
Good Answers: 143
Re: motor speed reduction
01/31/2008 1:48 PM
If you won't use a VFD, what about DC?
02/01/2008 10:10 AM
below 50% load not working already tried with 40v dc motor about 0.6hp motor
01/31/2008 3:15 PM
Variable pitch sheave?
Good Answers: 114
02/01/2008 12:24 AM
Please clarify the statement below?
What sort of mounting, shaft size?
02/01/2008 10:26 AM
my motor rpm is 840
two v belt connected between motor pulley and drive shaft.
when motor pulley rotate three turns drive shaft complete one turn.
when drive shaft rotate one turn my mechanism travel 3 mm.
if i apply very short time pulse for motor on ( around 1 sec Approx.) mechanism move up to 5mm.
todays my observation are as follows even if i apply brake for slide still it moves as is.
if motor run at 200 to 300 rpm may problem solved. ( but without loosing torque) else may be required gear box. for reduction.
Good Answers: 247
02/01/2008 12:44 AM
Drive a ball screw? Use hydraulics? Use a DC motor, or a stepper motor?
Belgium - Member - New Member
Good Answers: 21
02/01/2008 6:52 AM
rewind the motor to 8 or 12 poles
Good Answers: 59
02/01/2008 4:17 PM
If you need just a fixed reduction ratio, chain or gear reduction gears provide higher ratios, than belt. Planetary gears can provide up to 100;1 reduction.
But if you want variability:
Three phase motors are designed to run almost synchronously with the 3 phases. Their slip from it generates the current that drives them. So, VFD (variable frequency drive) is the ticket.
But since it is such a low power motor, a brush motor with an electronic feedback driver (sensing speed) would fill the ticket nicely.
Register to Reply 8 comments
Anonymous Poster (1); Blink (1); Garthh (1); jarunmagnet (2); leveles (1); rudy.leurs (1); TVP45 (1)
