Previous in Forum: potential free contact   Next in Forum: Intools software
Gas Supply at High Flow and Low Pressure Design
02/04/2008 5:37 AM
I have five N2 cylinder Having capacity of 6 cubic-meter each connected simultaneously to supply regulated N2 air.
I have three Evaporator instrument each consumption capacity 150l/min at 15 psi pressure need to connect to main gas supply line.
Distance between N2 Generator source & Evaporator is about 100m.
Please advise for tubilng Diameter, Pressure regulator {high flow ( 150 l/min to 500 l/min) & low pressure regulator (0 psi to 75 psi) to use in between line}.
Please help me in designing PI diagram for same.
Re: Gas Supply at High Flow and Low Pressure Design
02/04/2008 11:20 AM
Your question is pretty tough as asked.
Let me see how I 'm doing here.
You have a quantity of 5 (five) cylinders each at a volume of 6 cubic meters. The 5 cylinders are manifolded to a header with 3 outlets to support the three evaporators. Each evaporator has a capacity(?) of 150 l/min @15psi.
If this is correct then please indicate yea or nay. If not please correct.
If correct as I have stated please further clarify EXACTLY what you need to know.
I will just spit a random out now given the assumption that I am understanding you.
Try a 0-100 psi low flow pressure regulating valve compression fit to 1/4" diameter SS, teflon or PFA tubing.
cr3
Engineering Fields - Piping Design Engineering - New Member
02/05/2008 4:22 AM
Dear Sir,
Please check out diagram. there are five cylinders each having capacity of 6 cubic metre. This will work as my supply gas.
Evaporator are instrument which consumes N2 gas at 150 l/min @ 15 to 20 psi.( you can put inlet pressure upto 75 psi but you have to adjust inernal pressure of instrument upto 15 to 20 psi.This is my basic requirement.
Other tubings & Regulators are equipped in design by me for safety purpose of line pressure ( Regulator 1 will maintain line pressure upto 100 psi & regulator 2 will maintain pressure at inlet of evaporator- It is not mandatory to keep regulator)
I just want technical idea for tunbing ID & regulator sizing (as most of pressure regulators are high pressure/low flow regulators & we require low presure/ high flow regulator)
Please advise me for same.
02/08/2008 9:29 AM
If all you need is a regulator to meet those reqs then search GlobalSpec - our benefactor.
Otherwise I am not really seeing a question here.
cr3
