I have an application where a dedicated 2 MVA transformer supplies power to two identical loads in parallel (operated simultaneously using active sharing). Each load has its own set of distribution busbars. The obvious method to protect the transformer secondary is to place a properly sized current limiting fuse (about 3KA, 480V) between the secondary phases and set of busbars capable of handing the full load current. We would like to use a different configuration by using two separate bus with 1500A fuses each. This way, each bus size can be reduced to the available full load current of 1500A instead of the original 3000A. While this seems to make sense, I have not found any similar application to support this idea. I realize that the available short circuit current on each bus will be almost as high as if they were connected together but the thermal rating should be half. Is there a reason why this would be against the North American electrical codes? Thank you.
