Previous in Forum: Load Commutated Inverter - How does it work   Next in Forum: Bus Ducts Drawings in the Plan
LCD
02/06/2008 12:33 AM
We want to replace a broken diplay Hosiden 9N26-40 (broken glass).
It is a display that is not produced by Hosiden any more and it has following properties:
1. 320x240 dots
2. high voltage CCFL backlight
3. only four data leads: D0, D1, D2, D3
4. it uses OKI M5299A and M6598 dot drivers.
5. it uses LA5315M variable divided voltage generator for multiple drive of LCD matrix.
6. glass dimensions: 130x100mm (the new dsplay could be smaller)
We have identified all the leads of its flat input cable (14wires):
1. Vref LA5315
2. Vcc LA5315
3. D3 M5299A
4. D2 "
5. D1 "
6. D0 "
7. J1-B (no jumper)(probaly disconnected)
8. Vss
9. Vdd
10. CP 47 M5299A
11. Load 49 M5299A
12. 48 M6598
13 39 M6598
14. GND
Two high voltage CCFL leads are separate..
S přátelským pozdravem / Mit freundlichen Gruessen / Best regards
Karel Brož
údržba elektro / Elektro-Wartung
KERN-LIEBERS CR spol. s r.o.
Okružní 607, CZ 370 01 České Budějovice
Tel.: (+420) 389 608 088
Fax: (+420) 389 608 027
Re: LCD
02/07/2008 12:05 PM
?What is your question?
Good Answers: 12
Re: LCD
02/07/2008 3:25 PM
This is a problem as standards in the display industry change rapidly and product life cycles can be measured in months.
There is a company that offers a solution to this problem. VARTECH Systems, Inc. http://www.vartechsystems.com/ has made a business out of repairing obsolete displays and providing drop-in replacements.
Good luck!
Register to Reply 2 comments
