Previous in Forum: Bus Ducts Drawings in the Plan   Next in Forum: Restricted Earth Fault Protection
Transformer Maintenance Tools
02/06/2008 1:46 AM
Hi I am looking for two sets of tools for the transformer maintenance teams.
Dissolved gas analyzer and transformer insulation tester
can any one point me in the correct direction
many thanks
Bad things happen WHEN GOOD MEN DO NOTHING..GOOD MEN STAND UP
Pathfinder Tags: transformer tools
Re: Transformer Maintenance Tools
02/06/2008 11:37 PM
flegelo
Havent got the foggiest where you would find a "dissolved gas" analyzer but the electrical device should have several functions,ie==
opens--continuity checker.
winding resistance--good ohm meter--to detect shorted windings.
insulation test--a "meger" or high votage breakdown to detect leaks between the windings and the chassis (assuming it's metallic).
Granger &/or Greybar El. usually carry these instruments--I believe Granger has the widest selection.
Good luck--Donzi
02/06/2008 11:55 PM
hi
yes there is gas and moisture analyser is available for oil transformers which is online and continuous will give anlyse on PPM and RH% called HYDRAN system for x mers. We are selling The Product in india of make GE spyrotek- canada. if any body need more clarification contact me on mkrishnalal@prime-pci.com
Good Answers: 27
02/07/2008 2:07 PM
You can also obtain these instruments from Doble Engineering (www.doble.com). They make a line of Intelligent Diagnostic Devices (IDDs), including dissolved gas analyzers.
Register to Reply 3 comments
Bluestone (1); donzi (1); krishnalal (1)
