Previous in Forum: Shock Response Analysis   Next in Forum: Generation of power
How to calculate a tripod
02/06/2008 4:41 PM
Can a Tripod be calculated as a simple beam with a center load?
Re: How to calculate a tripod
02/06/2008 5:28 PM
Not my discipline, but I would think not.
Good Answers: 183
02/06/2008 7:02 PM
I do not know which kind of tripod you mean. If it is the structure of a pick and place robot or an other structure with all legs articulated at both ends then you can consider every leg as a beam loaded with an axial force since the articulations (bearings ) do not allow the transmission of bending moments.
The structure can be analysed as any other space structure consisting of beams. It is the usual way to analyse from a mechanical point of view such structures.
Your problem will be to determine the right values for the loads.
Good Answers: 21
02/07/2008 4:45 AM
What are you calculating?
MACA (1); nick name (1); user-deleted-1105 (1)
