Previous in Forum: Brass Casting Defects   Next in Forum: Permissible Rolling Ratios
Friend of CR4
Plastic RFID
05/04/2006 11:46 AM
Scientists have developed a high-speed RFID tag that uses plastic electronics. This approach lets manufacturers print an RFID chip directly onto a plastic substrate along with its antenna. Complex assembly steps are eliminated. Read more in this Philips Research press release.
The preceding article is a "sneak peek" from the May edition of the Materials Handling newsletter from GlobalSpec. To stay up-to-date and informed on plastics industry trends, products, and technologies, subscribe to Materials Handling today.
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Recycling
05/05/2006 8:32 AM
I wonder what will happen to these tags after they are used. Is there room for recycling? After all, products that are are made of plastic can be melted down and re-formed.
Plastic RFID
05/16/2006 1:01 PM
I assume that plastics are more inert and would have better applications on the human body. Just think, instead of hand stamps, you could get a temporary RFID "Tattoo" at a concert or a theme park. Not only could you be tracked, but you could be selectively hit with advertising for your favorite products and pastimes.
The Feature Creep
Re:Plastic RFID
05/17/2006 4:17 PM
Minnesota has already banned the use of mandatory RFID tags on people. Not sure if your application would fall under that as it is not permanent.
"The future is here. It's just not widely distributed yet." -William Gibson
Re:Plastic RFID
07/06/2006 1:21 AM
Bush will REMOVE the ban's everywhere! hee hee!
The Feature Creep
Re:Plastic RFID
07/06/2006 7:53 AM
Doubt it. That would alienate his fundamentalist base, many of them believe that RFIDs are the "number of the beast" from Revelations.
BRodda (2); Paddy O'Flanigan (1); Reversengineer007 (1); Steve Melito (1)
You might be interested in: RFID Software
