Previous in Forum: Designing Cryogenic Manifolds   Next in Forum: pine cone
14 comments
Good Answers: 183
Heat resistent material
02/08/2008 1:33 PM
Hi ,
For a project i have to evaluate now i am confronted with a support which work for short periods of time in contact witj hot gases temperatures up to 1200 °C.
Could any body make some suggstions ?
I would appreciate.
Thanking in advance
Pathfinder Tags: 1000°C resistent material
Good Answers: 143
Re: Heat resistent material
02/08/2008 1:47 PM
What are your constraints? There are a lot of materials that will withstand 1200°C.
Good Answers: 183
02/09/2008 4:22 AM
The material should be given a profile better on usual machine -tools
Loads are not important
Better if thermal diffusibility low
Price is not the concern
Good Answers: 243
02/08/2008 9:34 PM
Are these hot gases Oxidizing? Reducing? Must support be metallic? Nature of forces such that ceramics can withstand? What is load? Is support in tension or compression? These are the kinds of constraints TV45 is suggesting you provide.
I would also ask, what is budget?
The host of this site, global spec, hosts a material search utility. you might have some success browsing here:
http://www.matweb.com/Search/MaterialGroupSearch.aspx?GroupID=181
You can click on either the ceramics link on the left map, or on any of the titanium links for starters.
milo
Good Answers: 183
Re: Heat resistant material
02/09/2008 4:30 AM
I shall answer in same order:
1-The gases can be both
2-Not especially but it would be preferred due to the need of manufacturing a profile in order to reduce drag at almost sound speed of gas jet
3-Load is low
4-Load leads to a bending so that both tension and compression are present
5-As i mentioned the project is in "evaluation" so that a budget cannot be already estimated but considering some factors the cost can be secondary.
Do you have any suggestion beside the search on the recommended link?
02/09/2008 7:53 AM
Your question is short of information, but try Tungsten
02/09/2008 3:13 PM
If it is support during brazing, try graphite
02/09/2008 3:31 PM
Another line of thought is cooling. Put some internal plumbing in the support and run compressed air through it. Of course thermal shock/stress is more of a factor.
Brad
Good Answers: 183
02/10/2008 4:20 AM
It was my first thought but the project for many reasons avoids this solution.
Cooling is also a problem since heat transfer is time dependent and thermal difusibility so that if a high temperature flank comes the cooling of the surface takes a time and the surface can reach the high temperature. From an other point of view cooling generates a lot of thermal strains due to the gradient. It ca also lead to a deformation due to same temp grad.
I am very thankful to all of you. I found the family of alloys heat resistant with help of google it is a high Cr alloy (up to 20%) category with a main usage in aeronautics (turbines for instance).
02/11/2008 1:53 PM
Nick:
Try this link: www.pipingtech.com
They make many different kinds of supports and can handle high temps as well as cryogenic. Their phone number is 713-731-0030. Ask for Joyce Stallings.
Hank
02/26/2008 1:54 AM
Hi,
I am dealing with the problem of heat resistant alloys for 5 years yet. Especially I'm dealing with nickel based superalloys. These alloys can operate at temperatures up to 1200 centigrades well. They have excellent behaviour at creep conditions, but if there are no external stresses (or small - up to 60MPa at this high temperature) their lifetime is very very high. Also superalloys have excellent corrosion behaviour. After 1000 hours at 1000 centigrades the weight increment is only around 240 x 10E-6 g/cmE2. I recommend nickel based superalloy CMSX-4.
Materials are all around us... ... so we must try to understand them
Good Answers: 183
02/26/2008 10:18 AM
Hi MG,
Thank you very much for the information Could you send more data or a link to get more data about the alloys family you mention?
I would appreciate.
Nickname
02/27/2008 2:16 AM
Hi,
here you can find some more information about superalloys generally: http://www.msm.cam.ac.uk/phase-trans/2003/Superalloys/superalloys.html
also, there are information at the site of C-M Group (they are producing single crystal superalloys): http://www.c-mgroup.com/cmsx_alloys.htm
the another supplier is Doncasters: http://www.doncasters.com/index.php?s=0
Good luck
MG
Good Answers: 183
02/27/2008 3:22 AM
Thank you
Nickname
11/11/2008 10:29 AM
what form this material is supposed to be in ?
if the wire - the best is tungsteen
tjako
Register to Reply 14 comments
dkwarner (1); garth (1); Hankt (1); MG (2); Milo (1); nick name (5); tjako (1); TVP45 (1); U V (1)
