First I know not to back feed my panels.
Here's my situation:
1) One Meter
2) Four 200A main panels with a total of about 100 circuits
3) I have a small power generator 7.5KW
Now when the power goes off, I would like to turn off the 100 circuits in the 4 panels, then fire up the generator, and then selectively turn on circuits. Then turn those off and turn on a few others. Example: Run the freezer for 1 hour then shut it off, run the heater for 2 hours then shut it off, run the computer and lights in office for a while, etc.
QUESTION:
What do I need to prevent my generator from back feeding? The transfer switches I've seen only permit a few predetermined (like 10 circuits) to be selected. I need to be able to MANUALLY rotate between up to 100 circuits.
Ideally, I would like a single switch that when thrown, cuts off the grid and connects my generator to my 4 panels. This would isolate the grid from my generator and vice versa. Is there something like this which can be installed between the meter and my panels? I want the least expensive method which is safe.
It seems like a DPDT switch would do the trick. It'd have to handle 800A which is fed from the meter to the four panels. One position would feed the panels from the grid, and the other would feed the panels from the generator.
I look forward to your feedback and thoughts...
Thank you.
