Previous in Forum: Sensors   Next in Forum: plc
Pressure Gauge
02/18/2008 6:53 AM
How to calibrate a pressure gauge?
Re: Pressure Gauge
02/18/2008 9:17 AM
what type of a pressure gauge do u have, if it is Bourdon tube then u can check How to calibrate the Pressure gauge asked by Gunace
gravity, u win again
Re: Pressure Gauge
02/18/2008 10:12 AM
Take a look here http://msl.irl.cri.nz/training_&_resources/Technical_guides/TG13.pdf
Re: Pressure Gauge
03/21/2008 3:03 PM
There are many places that do this. It is probably cheaper than doing it yourself.
To do it yourself you would need either a master that is occasionally sent away to be calibrated or a dead weight tester. Dead weight testers cost about $2000. They don't have to be calibrated.
You must also check the span as well as one specific pressure point. The gauge may be accurate at midrange or elsewhere and off at other points.
Note. Don't assume that new gauges are accurate. Many times they aren't. I saw one that actually had the pointer pegged on the wrong side of the stop.
Peace be upon you.
Anonymous Poster (2); Skelley (1); stemere (1)
You might be interested in: Pressure Gauges, Pressure Sensors, Pressure Switches
