Previous in Forum: Meet Nikola Tesla   Next in Forum: Turn Plastic Bottles into Rockets
Balance Drum Working in Centrifugal Pump
05/16/2006 2:15 PM
ch Shahzad Hussain writes:
Please describe in detail the workings of a balance drum and balancing disc, both in combination in centrifugal pump for axial thrust adjustment.
some help
05/18/2006 10:04 AM
I believe these are used in magnetically coupled seal less pumps for "automatic" adjusment of thrust loads. Check out http://www.dickow.de/e/content/MultistageCentrifug alPumpsTypeHZMR.asp for a description and picture. Also, search for info on the specific manufacturer of the pump you are interested in.
Re: Balance Drum Working in Centrifugal Pump
07/31/2007 7:36 AM
you can ask mr. ikram in utilities machinery
02/07/2009 7:31 AM
plz tell me about working of balanceing drum
07/02/2010 9:07 AM
what is the purpuse of balance drum and whwre it is installed
11/15/2007 8:00 AM
The combination balance disc and drum arrangement used in some multi stage centrifugal pumps basically maintains uniform hydraulic axial loading through small changes in the axial clearance between a rotating and stationary disc. As the pressure rises on the balance chamber side it forces the stationary and rotating discs closer together, reducing the clearance between the disc faces and slowing the flow across the drum / bushing component of the arrangement, causing the pressure on the discharge side of the disc faces to build and push the rotor back towards the balance chamber until a state of axial balance is reached. The reason for using the drum / bushing component with the disc is to better control the pressure in the balance chamber. This a very basic explanation, more info on this subject can be found in a few of Igor Karassik's books. (Pump Handbook, Centrifugal pumps)
You might be interested in: Centrifugal Pumps, Drum Pulleys, Drum Heaters
