Previous in Forum: Fuses AC and DC   Next in Forum: protection of welding machine
earthing in aircraft and ships?
02/21/2008 4:46 AM
how can design earthing system in aircraft or ships???
Good Answers: 918
Re: earthing in aircraft and ships?
02/21/2008 7:01 AM
You should look into FAA and RTCA regulations and "MOPS".
All of that will be spelled out in very painful detail.
Good Answers: 21
02/21/2008 7:22 PM
In aircraft you recruit gremlins to hold the wire against the frame in various places...sometimes they can forget which wire it was supposed to be...and let a little itty bit of smoke free. Then you chase down and kill the gremlin.
Speed doesn't kill. Sudden stops, brick walls, and old ladies in Buicks do.
02/21/2008 11:04 PM
In ships its like off-shore platform earthing. In aircraft earthing system is not required. its all floating neutral.
BNDas
Location: N.E. Alberta 55.6329 N Lat. 111.0729 W Long. Canada
02/23/2008 3:29 AM
Depends on what kind of platform you have. If it's on stilts you have a fixed point. If you have one with pontoons, its floating. The aircraft one is definitely an isolated from ground system.
Could be worse, it could be me. :)
Register to Reply 4 comments
Anonymous Hero (1); biswanath.das (1); mayt2u (1); Switchman (1)
