Previous in Forum: Level Calibration Range   Next in Forum: How do I use a Coordinate Measuring Machine.
DC Pump for Water Circulator
02/25/2008 1:01 AM
We need a small 12 V DC pump for use in a circulating water bath ( used with viscometer )with temperature range 10 deg C to 50 deg C . Continuous rating type .
At present we are using the windshield washer pump of car .
If anybody can give information ..it would be very helpful.
aks
Re: DC PUMP for water circulator
02/25/2008 4:01 AM
The windshield washer pump will probably burn out, they are rated for very intermittent use.
A small commercial peristaltic pump will do the job (like a big version of your windshield washer pump)
You don't say what country you are in!
In UK the company I work for could help chemicalcontrols.co.uk
Do a search for 'peristaltic pump' you may find a single pump unit designed for dosing detergent into small commercial dishwashers/glass washers will do the job nicelyat a reasonable price.
Good Answers: 15
02/25/2008 6:23 AM
another option is to use a pump from a tabletop water feature.....
If you don't have time to do it right the first time, when are you going to have time to do it over?
Popular Science - Weaponology - New Member Engineering Fields - Aerospace Engineering - New Member Hobbies - Model Rocketry - New Member United States - Member - New Member
Re: DC Pump for Water Circulator
02/25/2008 11:15 PM
Common bilge pumps are 12V DC and very reliable in continuous or semi continuous use.
Check out Rule pumps (http://www.rule-industries.com/products/pumps/index.htm). The bilge pumps might be higher flow rate than you need (they start at about 360 gph), but they have some smaller types. They are pretty cheap and you can find them at a local marine shop or on ebay pretty easily.
Those pumps are made to work under significant head, so if you want to lower the flow rate, you can partially cover the intake without worrying about burning out the motors.
They also work well with simple pwm control if you end up wanting to vary the flow rate.
Small fish pond or fish tank pumps might work well also.
02/25/2008 11:19 PM
we used a brass oil pump with a step down motor it has about 1 gallion per hour of transfer and can run forever no problems.
princess auto was where i got the pump and the motor
Richard
Hobbies - CNC - New Member
02/26/2008 2:28 AM
Check out part suppliers for motorhomes and recreational vehicles.They all use 12 volt pumps for fresh water systems. Most of these pumps are for cold water supply, finding a pump for hot water (50 deg. C) may be a challenge!!!
Best of Luck, Gary
02/26/2008 6:50 AM
I'm tempted to say use a 12V to mains inverter and a central heating pump.
Both are common and therefore cheap items.
Re: DC Pump for Water Circulation
02/26/2008 6:57 AM
When asking for pump, It would make a lot of sense to specify flow rate.
A bilge pump is a good idea as long as your temperature is not over 35°C, What you need is a hot water circulation pump same as used on diesel water heaters or alike. Try to google Kabula Heaters, 12/24VDC BOLIN pump, if the flow rate you need doesn't exceed 10GPM or so.
Hope it helps,
Wangito
Never trade luck for skill.
Register to Reply 7 comments
Butcher (1); charlie_r (1); Magnacoaster (1); messager (1); Randall (1); user-deleted-1105 (1); wangito (1)
You might be interested in: DC-DC Converter Chips
