Hi,
I am considering renovation of a old LV distribution panel having 3-Pole and a reduced neutral busbars having 800 Amp rating, the configuration of the panel is -
1. Main Incomer ( 240 Sq mm 3.5 core,1100 V XLPE Aluminuc cable) - 400 Amp ICTPN switch
2. 8 outgoing through ICTPN switches of 300 and 200 Amp rating.
I would like to request comments on whether I should go for a TPN busbar arrangement or 4-Pole. The presently installed distribution panel is having copper busbars whereas I am thinking for 4-Pole Aluminum busbars with larger section as also 4-Pole MCCBs, 'coz space is not a constraint. I have observed problems in digital panel meters; would it be good to have analog meters. Finally what should be the voltage (mili volt) drop between the cable conductor and end termination (Cable lug) after energizing.
Regards,
Kamal
