Previous in Forum: Material Failure / P91   Next in Forum: IGC Test
non metal PVD target materials and process enquiry.
03/03/2008 12:56 AM
I am working on the mobile phone project that required to do non metal PVD thin film on the phone cover, the purpose is for appearance/cosmetic finish. it can be look like metal or other finishing. the phone cover substrate is plastic molded ( PC, ABS/PC , PMMA etc )
I am looking for supplier ASAP now, please help.
Thanks,
Surface
India - Member - Isloorkar
Re: non metal PVD target materials and process enquiry.
03/03/2008 11:09 PM
4.3.08
I suggest you look up www.balzers.com and www.cemecon.de
If they tell you there aint no solution for non metal PVD, then there aint no solution for non metal PVD. If there is one, either of them will give you one or guide you to someone who's got one.
Regards,
03/03/2008 11:25 PM
4.3.08
Try also contacting:
Impact Coatings
Westmansgatan 29
SE-582 16 Linköping
Sweden
Regards,
03/04/2008 1:42 AM
4.3.2008
Physical Vapor Deposition (PVD) Coatings: PVD coatings involve atom-by-atom, molecule-by-molecule, or ion deposition of various materials on solid substrates in vacuum systems.
  • Thermal evaporation uses the atomic cloud formed by the evaporation of the coating metal in a vacuum environment to coat all the surfaces in the line of sight between the substrate and the target(source). It is often used in producing thin, .5 µm (20 µin), decorative shiny coatings on plastic parts. The thin coating, however, is fragile and not good for wear applications. The thermal evaporation process can also coat a very thick, 1 mm (.040 in), layer of heat-resistant materials, such as MCrAlY — a metal, chromium, aluminum, and yttrium alloys, on jet engine parts.
  • Sputtering applies high-technology coatings such as ceramics, metal alloys, organic and inorganic compounds by connecting the workpiece and the substance to a high-voltage DC power supply in an argon vacuum system (10-2 - 10-3 mmHg). The plasma is established between the substrate (workpiece) and the target (donor) and transposes the sputtered off target atoms to the surface of the substrate. When the substrate is non-conductive, e.g., polymer, a radio-frequency (RF) sputtering is used instead. Sputtering can produce thin, less than 3 µm (120 µin), hard thin-film coatings, e.g., titanium nitride (TiN) which is harder than hardest metal. Sputtering is now widely applied on cutting tools, forming tools, injection molding tools, and common tools such as punches and dies, to increase wear resistance and service life.
Source:www.efunda.com/processes/surface/thinfilm_coatings.cfm
Register to Reply 3 comments
