Previous in Forum: Single-Bearing Alternator vs. Two-Bearing Alternator   Next in Forum: What is Cathode Ray Protection?
11 comments
Summation CT
03/05/2008 1:17 AM
To measure current/power of two or more feeders by one ammeter/power meter summation CT is used. If all feeder contain same CT ratio, its cool. But if CT ratio is different in each feeder say, 600/5, 300/5, 200/5, 100/5, 400/5 etc, will summation CT can be applicable for accurate measurement?
BNDas
Re: Summation CT
03/05/2008 6:24 AM
NO.BCOZ DIFFERENT CT RATIO CAN CREATE THE DIFFERENCE OF ACTUAL LOADING i.e. IF THE CT RATIO IS 500/5, SO AT SECONDARY THERE WILL BE 5 AMP ONLY WHEN ON PRIMARY SIDE THE LOAD IS 500 AMP.
SO FROM THIS EXAMPLE YOU CAN UNDERSTAND THAT THE SECONDARY 5 AMP HAS DIFFERENT LOADING ON PRIMARY SIDE, ACCORDING TO ITS RATIO.AND IF THE CT RATIO IS 200/5 THERE WILL BE 200AMP ON PRIMARY SIDE AT THAT TIME THERE WILL BE 5 AMP ON SECONDARY SIDE.
PRAKASH VAGHELA
Re: Summation CT
03/05/2008 7:16 AM
It appears No, but actually Yes. Let's wait for sometime and I will come back.
BNDas
Re: Summation CT
03/06/2008 1:47 AM
No The different CT ratio, if secondary is same, but the primary side rating is different therefore it cannot be used for the summation bcoz there wont be actual result.
Now if the CT ratios are like 100/5, 200/5 , 300/5 , 400/5 etc.
So in case of 100/5 Amps there will be 100 amps on primary side at that time 5 amp amp on sec. side.
While in 200/5 amps there will be 200 Amps on primary side at that time 5 amp on secondary side. Now both are connected in same system so that loading will be different but the CT sec. will do the summation according to its sec. side current and sec. is depending on primary side, according its ratio.
So bo th the case load is different but summation of 5 amp on sec. side due to its ratio.
No
PRAKASH VAGHELA
Re: Summation CT
03/06/2008 1:50 AM
Mr vaghela,
Have you used ICT any time? Think how this can be used for summation CT.
BNDas
Re: Summation CT
03/07/2008 3:26 AM
Well I have use the ICT?
Is it Intereposing CT.Which has nearly same ratio near to 1.
Can you tell me further about ICT.
PRAKASH VAGHELA
Re: Summation CT
03/06/2008 6:40 AM
No,
In current summation all CT's must have the same transformation ratio.
If your current reading equipment is analog, change it or add digital, and than do a digital summation. there are several companies making this type of a calculator.
Wangito.
Never trade luck for skill.
Re: Summation CT
03/06/2008 7:11 AM
You are wrong!! using Intermediate CT different ratio CT can be summationed. Think over.
BNDas
Re: Summation CT
03/06/2008 9:53 AM
I don't think I am,
Suppose we have a three phase system where all phases have same current which is 100Amp. Case 1, where CT's have all different transformation ratios:
  1. CT #1 is 100/5 will read 5Amp
  2. CT #2 is 200/5 will read 2.5Amp
  3. CT #3 is 400/5 will read 1.25Amp.
Total instrument reading 8.75Amp.
Case 2, where all CT's are same transformation ratio:
  1. CT #1 is 100/5 will red 5Amp.
  2. CT #2 is 100/5 ditto
  3. CT #3 is 100/5 ditto
Total instrument reading 15.0Amp.
Wangito.
Re: Summation CT
03/06/2008 12:24 PM
wanqito good example make all CT's 600/5
Re: Summation CT
03/07/2008 1:09 AM
Bhuuuuu!!! Well let me explain.
CT 600/5, 500/5, 300/5 in three different feeders.
ICT of ratio 5/4.17 for 500/5 is required
ICT of ratio 5/2.5 for 300/5 is required
No ICT for 600/5.
600+500+300 = 1400 corresponds to 4.17+2.5+5 = 11.67 A
summation CT ratio 11.67/1 A. That is 11.67 = 1400A
Now if 600/5 feeder is off, and other two feeders are fully loaded the total primary current is 500+300=800 corresponds to 4.17+ 2.5 = 6.67
Means (1400/11.67)*6.67 = 800 A
Did you get?
BNDas
Re: Summation CT
03/09/2008 12:58 AM
Regards to all !
Take example from the question:
600/5, 300/5, 200/5, 100/5, 400/5 Amps
Following pionts be kept in mind
1. Most of the CTs in power-distributin have */5A with a specified "Dump" in VA which should be maitained in all cases.
2. Phase displacements in different feeders must be considered. otherwise NO result accuracy or even approximation be thought of.
3. Out-put of CTs to Meters be considered how it is being fed;
without rectification [AC-Ammetre] or rectified [DC-Ammeter].
My view:
a. All CTs [for AC Ammeters] can only be summed only if phase is also same in addition to the same Ratio, Dump values.
Note:
In some cases where the construction of CT allows:
600/5, 300/5 CTs can be combined by making 600/5 can be modified to 300/5 by passing 2 turns through CT & 400/5 to 200/5 by the same way.
b. All CTs [for DC Ammeters] should only have the same Ratio & Dump values.
<< If all feeder contain same CT ratio, its cool >>
I think that the phase displacement is the most important in Power measurements, which must be considered primarily.
Register to Reply 11 comments
biswanath.das (4); Haajee (1); mrprakashvaghela (3); perry (1); wangito (2)
You might be interested in: Stock and Strip Feeders, Parts Feeders, Solids Feeders
