Previous in Forum: Transformer and Motors   Next in Forum: Replacing an NPN Sensor with a PNP Sensor
Differences Between Transformer Types
03/05/2008 8:19 AM
good day for all.
i am going to make a comparison sheet between conservator type transformers and oil type transformers (construction, quality, type test & advantage/disadvantage).
can any body point me how can get it.
thanks at all.
Eng. sanad Migdad
Re: Differences Between Transformer Types
03/05/2008 8:47 AM
I apologize for the inconvenience in the previous post. this is the correction of previous information.
in fact the comparison sheet it will be between oil conservator type and hermetically sealed transformers.
again i apologize.
thanks,
Eng. Sanad Migdad
Good Answers: 42
03/06/2008 7:31 AM
Hi,
First you make a comparison sheet and put in this forum then people can add more points and correction to it .Hope you will agree with me.
Regards
03/06/2008 9:45 AM
In both the Types The Transformer is just similar except the Conservator. In Conventional Transformers the Oil in the Conservator is in contcat with the natural air at atmospheric pressure. For small Transformers upto 33 KV, 1 MVA, the vacant portion of the Conservater can be filled with Nitrogen and seal it for any leakages. Bigger size Transformers from 132 KV onwards for Hermitically Sealed or Atmoseal Transformers the Oil in the Consevator is cushioned by the Rubber Belly containing the Natural Air and hence the Oil in Consevator will not be in direct contcat witrh the Natural Air containing some Moisture. Hence Quality of Oil can be kept at satisfactory level.The only disadvantage is that it is difficult to acertain the Healthiness of the Belly. Any Leak in the Belly can convert the Atmseal Transformer to a Normal Transformer. It is desirable to use Atmoseal Transformers.
Ramana.
Anonymous Poster (1); Ramana (1); V.I.Abraham (1)
