Previous in Forum: Repost: How to argue Cpm over Cpk (Process Capability Indices)   Next in Forum: specefication
HELP Needed on welding problem
03/07/2008 8:33 AM
Hi need to calculate solve this question but I could not get the proper way to solve this..
Can anyone suggest some ways to salve these
The ability of the heat source to melt the base metal is an important consideration in fusion welding.
Melting efficiency (as distinct from energy transfer efficiency, h) is defined as follows:
Heat needed to melt weld metal
Total heat input
Use the data in Table to calculate the energy need to melt 1 mm3 of carbon steel (starting at 20 °C).
Hence find the minimum power needed to generate a bead on plate weld of 15 mm2 cross sectional area in carbon steel at a welding speed of 4 mm/s.
For this weld, the actual power input was 2 kW. Calculate the melting efficiency.
TABLE
Metal r C
m
C
V
T
M
DH
m
l
kg m
-3
kJ kg
-1 K-1
kJ m
-3 K-1
°C
kJ kg
-1
Wm
-1K-1
aluminium 2700 0.900 2430 660 410 200
carbon-steel 7900 0.450 3555 1535 270 65
titanium 4500 0.520 2340 1660 320 20
copper 8800 0.59 5192 1083 200 385
nickel 8900 0.45 4005 1455 300 55
r density/ kg m-3
Cm specific heat per unit mass/ kJ kg-1 K-1
CV specific heat per unit volume/ kJ m-3 K-1
DHm latent heat of melting per unit mass/ kJ kg-1
Tm melting temperature/ °C
l thermal conductivity / W m-1 K-1
This discussion was "closed" on 03/11/2008 7:18 AM. No new comments are allowed.
Message from admins:
Homework
Good Answers: 266
Re: HELP Needed on welding problem
03/07/2008 12:51 PM
Try one of these
03/09/2008 12:50 PM
This is an assessed coursework. Please be aware of the university guidance on seeking outside help and its plagiarism rules. It is against university policy to publish information without consent.
This information will be reported
You have been warned
03/09/2008 7:43 PM
Please repeat your question and wait my answer?
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
03/10/2008 3:30 AM
Sorry shivarajs, but I don't think you are an engineer asking your colleagues. According to the form the problem is written it seems like a classroom problem. You give the definition of melting efficiency and you have the actual power, so you need just to calculate the melting energy from the data included in the table, and as you have welding speed you can get energy from power.
If you don't know this very simple concepts, you may ask your teacher.
Cheers
Register to Reply 4 comments
Homework
Abdel Halim Galala (1); Anonymous Poster (1); Kwetz (1); ozzb (1)
