I am considering a material which would have a wet (water) side and a "dry" (atmospheric air) side. The dry side would possibly be higher pressure, but in any case the air is allowed to transit through the material to form bubbles on the surface of the material on the wet side. The water wouldl be largely excluded from transmission, although not necessarily exclusively so. Aerogells come to mind, or some kind of semi-permeable membrane perhaps. It wouldl convenient for the air bubbles to be very small and numerous and tend to adhere to the material in the face of flow across the wetted side.
While i am not a materials scientist I have researched this and discussed it with some who are, but none were really helpful. It is my hope that you will be able to identify issues and considerations (or even materials
) I have not found. Even something that is close would be helpful.
I am sorry that I cannot discuss the application.
Thanks for your time and consideration.
r/
Sam Hicks
“Truth is stranger than fiction, but it is because Fiction is obliged to stick to possibilities. Truth isn't.” – Samuel Clemens in Following the Equator, Pudd'nhead Wilson's New Calendar
