Previous in Forum: A Good Earthing Should?   Next in Forum: Seismic Buildings
Suitable motor?
03/10/2008 1:46 PM
What is the suitable motor for the robotics with high rpm and 12v supply?
Re: Suitable motor?
03/10/2008 3:44 PM
A Dremel! It all depends on what you are trying to do! If you can give us something to play with then maybe we can suggest something else! Is it for rapid positioning? Does it need a feedback loop? Is it for a flail? Is it a secret that you are not allowed to tell?
I have a question for you! How do I change a tyre?
N0, I take it back to the shop!
Give us some more info!
Re: Suitable motor?
03/10/2008 7:08 PM
Do you mean motor gearbox assembly or just a bare DC motor?
Is this a low power application? What load are you moving?
Do you want one offs or are you going to use a lot of 'em.
Look at Rotalink the make a nice range of cheapish low power motor gearbox assemblies
Re: Suitable motor?
03/10/2008 7:42 PM
Trident engineering do a good range of small motors & gearheads (some of their own, as well as being distributors for Portescap etc.).
As others have said - depends what you want - is it for a robot car crusher or a robot fly?
Re: Suitable motor?
03/11/2008 9:41 AM
Most Robotic application that I have seen used steppers or servo type motors with or without encoders. These motors are for low torque high speed application and will require a dedicated controller.
Good Answers: 80
Re: Suitable motor?
03/11/2008 10:16 AM
If you are looking for a hobby source, you can recycle old cordless drills using the 12V batteries. Just ask around and you should find some. People usually discard them when the battery is too old because it is cheaper to buy a new one than to replace the battery. These drills come with a gearbox and usually have two speeds.
Re: Suitable motor?
03/11/2008 10:50 AM
Where is krishna_phelu?
Re: Suitable motor?
03/31/2008 3:19 PM
I would use a round one, versus a square one...
Register to Reply 7 comments
Anonymous Poster (2); JohnDG (2); marcot (1); Mr. Truman Brain (1); user-deleted-1105 (1)
