Previous in Forum: Will these Motors/Potentiometers Work for Me?   Next in Forum: switchgear
Replacement of UPS Batteries
03/12/2008 12:46 AM
Dear All.
I have a UPS Powerware brand 220V 3000VA. It have dry batteries which provide 96V to UPS. Now these batteries have dead. I want to replace these batteries with 8nos motocycle (wet) batteries (12V 6AH) because its original batteries are no longer available in market. Is it possible? Have anyone experienced such a case?
Engineering Fields - Energy Engineering - New Member India - Member - Jack of all trades
Re: Replacement of UPS Batteries
03/12/2008 1:50 AM
Its not advisable to replace the original batteries with conventional lead-acid batteries, you should instead go for SMF batteries. YUASA is one of the good makes.
Kind regards,
Kamal
It takes considerable knowledge just to reaIise your own extent of ignorance.
Good Answers: 42
03/12/2008 10:05 AM
The UPS batteries need to be sealed and maintenance free as they are installed close to work place. The normal motor cycle batteries are neither sealed nor maintenance free they require acid top up and boost charging and emit acid fumes. There are legal regulatory restrictions to use them near work area but have to be installed in separate room due to health hazard. There are many sealed battery of same capacity available in the market which can be safely used.
Good Answers: 61
03/12/2008 11:03 AM
I use flooded lead acid stationary batteries in most of my applications, but they are all located in well-ventilated areas of industrial facilities, with signs posted to warn against heat sources or open flame. In an office, laboratory or other enclosed setting, sealed or non-gassing (Ni-Cd or similar) batteries are required.
However, using motorcycle batteries is a bad idea for other reasons. A vehicle battery is designed for current draws lasting a few seconds at a time. Smaller motorcycle batteries cannot handle ANY high current draw because they are designed for bikes without electric starters. In comparison, a UPS battery is designed for a steady drain lasting 20 minutes to 8 hours (depending on the type of UPS). I suspect your motorcycle batteries would fail, or degrade to unacceptable levels, within 10 usage cycles.
If the motorcycle batteries are cheap enough to replace at that frequency, it might work. However, you are taking a system designed as a "last resort" backup power supply and significantly reducing its reliability. Your Uninterruptible Power Supply will become very interruptible.
04/08/2008 2:25 AM
Hi,
we are the south indian dealer for amco batteries. so the ups required smf battery. for replacement please call us
prashanth
bangalore
thank you
Register to Reply 4 comments
Anonymous Poster (1); j_kamal (1); pwr2thepeople (1); V.I.Abraham (1)
