Previous in Forum: Star delta starter: resistor calculation   Next in Forum: what is O-0.3s-CO-3min-CO for a Circuit breaker?
Closed transition resistor
03/12/2008 12:47 PM
Could you inform me how I can calculate the resistors (in ohms and watt values) of a Wy starter with closed transiton?
Thank you
Re: Closed transition resistor
03/12/2008 11:52 PM
First, thank you for registering, and welcome to CR4!
You need to give a lot more details. I suspect you are talking about a Wye-connected motor soft starter, but then...
03/13/2008 5:40 AM
Yes I am talking about a star delta motor starter. I know the way to calculate the contactors but I don´t know the way to calculate the value of the resistors in order to get a "closed transition".
The motor is 40HP, 1800rpm, 60HZ, 3x220VCA.
If this information is not enough, please, don´t hesitate to consult me.
thank you
03/13/2008 11:43 AM
That motor size is out of my range of experience, so I can't really help, but hopefully your added data will give someone else who does know, enough information to help.
Dick
Engineering Fields - Piping Design Engineering - New Member Technical Fields - Architecture - New Member
03/14/2008 6:57 AM
you better bug the starter manufacturer they will provide these in puts but you need to drive them mad thats what i have been doing best of luck
crm
Run silent run deep
Register to Reply 4 comments
crm (1); dkwarner (2); iturrospe (1)
