Previous in Forum: Pump- motor alignment (overhung) doubts-reg.   Next in Forum: sahip_yo1967@yahoo.com
Mixing of Gases at different pressures
03/14/2008 1:49 AM
What happens if two gases say gas 1 at 30 bar and gas 2 at 20 bar mixes to gether using a "T" arrangement?
And what if gas 1 is at 20 bar and gas 2 is at 19.9 bar?
Good Answers: 101
Re: Mixing of Gases at different pressures
03/14/2008 4:13 AM
This wouldn't happen to be your homework assignment now, would it?
Egypt - Member - Mechanical Engineer Engineering Fields - Mechanical Engineering - New Member
03/14/2008 4:48 AM
Using Dalton's law of gas mixtures
P= P1+P2+P3+P4+.....+Pn
where P:total pressure of gas mix
P1:pressure of gas 1
P2:pressure of gas 2
and so on
as long as P1, P2, P3, and P4 are mixed in one container.
i hope i was helpful.
A Rough Road Lead To The Stars
03/14/2008 5:01 AM
What is the pressure of the third branch? If it is lower than any of the two branches (such as an empty vessel), then both gasses will flow to the lower pressure.
To determine the actual pressure, try Dalton's law of partial pressures, or maybe even Bernoulli's equation?
DVader1000 (1); maverick2012 (1); Solrac (1)
You might be interested in: Gas Instruments, Gas Sensors, Bar Code Software
