Previous in Forum: How to get a smooth surface finish of Engineering Plastic Materials   Next in Forum: Mechanical construction@ fabrication
what is different between module & card system
03/15/2008 2:00 AM
Dear sir,
I am working in plastic industries.i have injection moulding machine.i have same company injection moulding machine.both are microprocessore machine.But in one machine there is card system(cpu card,input & outout card). and in second machine there is module system.My question is what is different between both system?
Re: what is different between module & card system
03/15/2008 6:52 AM
There's no fundamental difference - it's just a different way of packaging the electronics.
The comments below are general; there are always exceptions, so please, dear readers, don't shoot me down:
Cards needs a separate panel for controls & indicators - modules can have them on the front panel.
Modules are more robust - easier to replace in the field.
Cards plug into a backplane which can easily have over 100 inter-card connections; modules generally have fewer connections between them. Also, the backplane can carry active electronics.
In a lab environment, modules are usually preferred, as it's easier to reconfigure the mixture of module types & connections when setting up a system (not applicable to your injection moulding machines).
As I said, there are always exceptions. For instance, the Eurocard/Euromodule systems are essentially the same; take the card & wrap it up in a metal enclosure with the connector sticking out the back and a small panel on the front, and it becomes a module.
Hope this helps.
Reply to Forum Thread
