Previous in Forum: Solar Pump Installation   Next in Forum: roll stiffness calculation of trailing arm air suspension
Fumes Flow
03/17/2008 5:51 AM
Hello,
I'm working on the optimization of a curing oven. We have 2 exhaust chimneys (inlet/outlet) for the fumes generated by the process. Unfortunately, I can't make any accurate measurements in the ducts because the straight portion is very very short.
Here is the data I have:
- dry and wet temp. in the ducts, from which I can obtain the density d2.
- extraction fan speed, from the charts I can obtain the air flow for a density d1= 1.2kg/m3.
I'd like to know how I can estimate the fumes flow for the density d2.
Isn't it Q1/Q2 = SQRT (d2/d1) ? I got it using the formula Q=V1(m/s)*surface(m2)meaning Q1/Q2=V1/V2 with V1 function of SQRT(...../d1).
Thanks for your help.
William
Re: Fumes Flow
03/31/2008 10:50 AM
Actually, I checked the nominal flow of our exhaust fans (in normal cubic meters, ), then thanks to the dry temperature of the fumes temperature that I measured and the initial temperature, I calculated the power of the fumes in kW.
What do you think?
